Cluso's P2SBC board(s) - Developer and OS and CPM board (a new question)
Cluso99
Obsolete
New thread started here...
forums.parallax.com/discussion/172262/clusos-p2retroblade-and-p2maxiblade-interest-please/p1?new=1
Update
I’ve renamed the thread from “Cluso’s P2 OS and CPM board (preview)
The specs have changed from those listed below so please see the latest posts. I’ll start a new thread once these boards are ready.
Here is a preview of my P2 PCB capable of running my P2 OS and Z80/CPM
Features
* P2 (P2X8C4M64P) with 20MHz SMT xtal
* Transistor reset circuit (as per P1) - optional by pcb solder link
* LDO regulators for 3V3 and 1V8 (no switching power supplies)
* 1 TTL Serial port connector (can connect to cheap $1.50 CP2102 USB/TTL board) - for downloading code, PC connection, etc
* microSD - Boots from microSD (no Flash chip on pcb)
* VGA female connector
* 2 x microUSB connectors (direct to P2) - can connect to USB/PS2 keyboard and/or mouse, or provide 5V power to pcb
* 20 uncommitted I/O - 2 x 12x0.1" pitch connectors on 1" centres providing 3V3, GND and either P00-P09 or P38-P47 direct connections to P2.
* Size 1.3"x2.1" (VGA over hangs board by ~0.35") which minimises the footprint if the VGA connector is not fitted.
This board will not do everything for everyone! It will meet the low cost and simplicity of design though it does have enough general features for many uses.
Currently I am not certain whether I will produce this pcb because I am unsure of demand.
So I'm interested to hear your thoughts for the board as-is.
Note: The 3D connectors shown for the microSD and microUSB connectors shown are not the ones used as I don't have the correct 3D part files.
Update
Features
Is it being powered via microUSB? How do you split the power and HID?
I think the USB-A female to microUSB male cables that you would need for keyboards are OTG types which might make a difference maybe.
Are you doing this on a 2-layer?
Can be powered by either microUSB or the TTL header which may be from a ~$1.50 CP2012 board or just the 5V & GND pins. All are in parallel.
https://ebay.com/itm/CP2102-USB-2-0-to-TTL-UART-Module-6Pin-Serial-Converter-STC-Replace-FT232-Black/382658228394?epid=13013617291&hash=item59183530aa:g:AzIAAOSwgGZcB3PW
Need to check the microUSB (OTG?) to USB-A male cable connections to see if they will work.
Most people already have microUSB to USB-A male cables. Then just add a USB-A female to USB-A female gender bender ~$1.50
https://ebay.com/itm/USB2-0-Type-A-Female-to-Female-Adapter-Coupler-Gender-Changer-Connector/402362005886?hash=item5daea4f97e:g:THIAAOSw3WZfNkL3
Or, cut the USB-A end off the microUSB to USB-A male cable you already have, and replace it with the cable on your keyboard (provided you want to donate the keyboard to this project). A keyboard is only worth ~$10 these days. Same can be used for a mouse if desired but will require software to ustilise the mouse.
I'm thinking a P1 board (like my P8XBlade2) could be used to replace the keyboard IC and cable, converting the keyboard to a 3V3 serial TTL connection.
Yes, 2 layer. I'm contemplating adding provision for (but not fitted) underside bypass capacitors which might help the ADC. I did this on my original 1"x1" layout but it makes production more difficult so I shelved the design for now at least.
My expectations are that 500mA will be the max so I don't see any problems with this design as far as heat or power problems. IMHO the heat and current issues are way overstated and may only be present in complex edge case designs.
Just might help diagnosing start-up for new users.
dgately
It'll be interesting how warm it gets using LDOs. Hard to predict, better to just try it
I've measured my P2EVAL 5V current and the max I read was 140mA. While there is certainly more work available, I'm just not seeing any outrageous power usage in the target for this board.
The other problem is with such small diodes that they could reflow themselves right off the pcb with the heat that they will generate. With Schottky diodes you can have high currents because they have a much lower voltage drop but here you want the voltage drop and you want the current. Maybe you can't have both.
This board does make a lot of sense for me! Most of my projects do not need too many pins. Breadboard or experimenter pcb friendly! SD card is very useful!
Those 2 Leds would make sense but can be added easily by the user.
Perhaps you can add 5V to the right inline row?
Spi Ram would be nice.
But it is time, that a board like this becomes reality!
How much to add an 8 inch floppy disc drive?
Peter suggested I could trim an 8" to 5-1/4" just like I did for the 16 I/O P1
The pair of diodes drop 2.08V at 500mA which is about what I expected.
There is basically no copper for heatsinking on the diodes or regulators because each pin is soldered to the edge of a thru hole on a piece of protoboard.
Yes, the regulators get quite warm and the diodes do get a bit hotter. This is subjective of course. Neither are as hot as I had the original glob top P2 running. I've been turning my garage upside down looking for the temp probe but alas I cannot find it
While I doubt the diodes are going to unsolder themselves provided there is sufficient copper on the pcb (which I have space for), there isn't going to be enough difference to bother with the diodes. So I am just going to series the regulators as Peter suggested.
For 5V 500mA, the 3V3 regulator will drop 1V7 @ 500mA = 850mW. Assuming no 3V3 usage (worst case) then the 1V8 regulator will drop 3v3 - 1v8 = 1.5V @ 500mA = 750mW. Assume the P2 with 1V8 @ 500mA = 900mW. Of course there will be some 3V3 current and hence power. So provided the total current draw is limited to under 500mA then there will be no problem with this design. Sure, there will be some things you might not be able to do with this design, but they will be minor IMHO.
I found a microUSB cable to female USB-A and it meters correct so this is good alternative to using a gender bender.
I want at least one.
What happens to the uncommitted IO's. Is it possible to provide holes on the board even big enough for a 30guage wrap/bodge wire to get soldered into?
Doug
By daisy chaining the 3V3 regulator output to the 1V8 regulator input, at 545mA (load of 10 * 3R3 1/4W resistors) the 1V8 regulator gets too hot (I measure 80C) and shuts down. If I power the 1V8 regulator via two series diodes which gives an input of 3V, the regulator is fine at 545mA (I still measure 80C). The diodes get to more like 85C.
Now remember, basically there is no copper heatsinking on these diodes or regulators in my test setup, so in practice these parts will run cooler.
I light of these tests, I have decided to make two versions of the pcb.
P2_MiniBlade
This pcb (shown below) will now only have one miniUSB and the pair of I/O 0.1" pitch headers will now be 10 way instead of 12 way (retaining 1.0" pitch between connectors), so there will only be 8 I/Os (P0-7 and P32-39) brought out to the headers. A pair of LDOs will be used with the 3V3 feeding the 1V8 regulator (ie without diodes). The pcb now reduces in size to 1.1" x 2.075" 2.0” with the VGA connector overhanging the sides of the pcb slightly as well.
Here is a 3D model
P2_MaxiBlade
This pcb will use the dual 1A switcher IC MPM38111, will retain two microUSB connectors, and will be extended to bring out 12-16 I/Os per side (to be decided) by using a larger pcb. See post below.
P2MiniBlade
* pcb is 1.5"x2"
* two 20x0.1" headers with GND, 5V, 3V3, GND and 16 I/Os
* one 6x0.1" header with RST, SO, SI, 5V, GND, nc for connecting to CP2102 USB-TTL pcb
* two microUSB connectors for keyboard and mouse and/or 5V supply and/or possible PC connection via USB and P2 software
* microSD socket
* VGA female socket
* 20MHz xtal
* 1V8 from two SOT223 1A LDO regulators in series (steps down via 3V3)
* 3V3 from one SOT89 1A LDO regulator
Notes:
* No Flash chip
* At 600mA for the 1V8 supply the 3V3 regulator will dissipate 1.02W, the 1V8 regulator will dissipate 0.9W, and the P2 will dissipate 1.08W excluding the 3V3 dissipation.
* Probably will not do the P2MiniBlade now
I cannot reduce the pcb at the top end without moving the 6pin header in the center of the pcb off the 0.1" pitch
Anyway, I have compressed it back to 2"x1.5" and hoping I can move the 6pin hdr to keep it on the standard 0.1" grid.
Higher density ones, (like EDAC Inc. 634-015-274-992) are more expensive than the older, larger ones.
These
https://lcsc.com/product-detail/D-Sub-Connectors_D-SUB-15pin-three-rows-Female90degree-black-pitch2-29mm-Tin-plating-With-hex-screws4-8mm_C75754.html
are ~20c/100
So it's a trade off of what you want more : lower BOM, or lower PCB area.
https://au.mouser.com/Search/Refine?Keyword=200015213
Also ebay (and everywhere) have the 15 pin M-M mini gender changers if you want to plug directly into monitor they are only a dollar or two
Why don't you just put down a 16-pin header and use one of those common IDC to VGA adapters found on ebay? That way you can choose to use a socket or a direct plug into the monitor.
Was this done in KiCAD?
Kicad has been fairly easy to learn the basics. I haven’t exported the gerbers yet though.
Flash chips now come down to 2x3mm and even 1.5 x 1.5mm DFN, so there may be space to allow for one of those small packages ?
eg GD25D80CKIGR 8MBIT 3.3V SPI USON8 1.5x1.5x0.45mm
