E-Tools, HTML java-script electronic design tools, free for YOU.
Clock Loop
Here is something that you all might find usefull.
Its a webpage you open that has a list of tools you can use quickly.
mono555 calculator
resistor calculator
voltage divider calculator
RCtime calculator
LM317 calculator
Binary-Hex-Decimal calculator
Resistor color matrix
Series LED resistance calculator
And a OHMS LAW calculator.
Im sure theres more that can be added... If you have any suggestions... please do.
The attached file is a ZIP.
All applets / script / js have been removed, no exception list needed.
mono555 calculator
resistor calculator
RCtime calculator
LM317 calculator
They even keep my stuff longer than I can.
** P O O F **
And I've had to do the same thing myself too.
1986 Chevy EL Camino·· No prop yet
1984 Suzukie GS1100GK No prop yet
No file over 63kb did.
I hope they choose to fix this, because I among many other people have worked very hard at uploading quality information, code, examples, only to find that none of them work anymore.
Every day that goes by while these files are broken is yet another day that someone wanted to download a neat example or something, only to find that NOTHING HERE WORKS.
I surprised a practice run wasn't run to find out how to properly prepare the new forum files so the changeover would have gone smoother.
How long before the files get fixed? Or will they ever?
The files will be updated over then next few days to correct any files that were inadvertently truncated.
Thanks for the great work! We forums members may come across as a bit harsh, but we all know your doing your best!
The first post has the file.
The first post has the file, lol.
Bumper ... cars...
No more java applets and java file exception lists... the tools are all contained in the html files.
@"Clock Loop" I hope that's ok with you. LMK if you disapprove.
I don't, but many people like to work offline, like myself, that's why I made it, and figured others would like it.
If people don't mind visiting a 3rd party site for it, thats up to them,
but it presents the possibility that a 3rd party site would dissappear all of a sudden (life sucks sometimes).
Also 3rd party sites can integrate harmful code, tracking cookies, IP tracking, ADs, etc...
But you would NEVER do any of that!
The code does have javascript, inside the html files, but there are no applets, or .js files, or anything that requires special java permissions.
Beware, I do not own the code, it was chopped from the internet, so I don't know if that will get you attention,
if google scrapes your site, and someone sees you have their code on your site.
Just don't point anything in that link back to parallax forums or this thread...
USE AT YOUR OWN RISK!
(if someone had issue with the code, i would just find another source of similar code, there are a billion)
What do you get when you stick a resistor in both ends of a jelly bean? answer
