QS Prototype board questions
Buck Rogers
in Propeller 1
Hello!
I have here one of them. This just the bare board. It has two positions for the connector on the QS, one has it position over the device directly, and the second is offset. According to the datasheet it enables the user to see the LEDs on the bottom and the contact pads. However, are they connected internally, that is inside the (presumed) multiple layers of the PCB? What I had in mind when I obtained it was to mount two rows of break-away headers on the first, and what we push the connectors into on top, that is in the second. Oh and single one of these on the spots on the right hand side, two in VIN and VSS, and one for 3.3V (VDD)
It happens I thought of that board for the problems related in an earlier thread, Powering a QS board and as a final idea for what was confirmed in the PAB thread for the camera board from Adafruit.
Here's the bottom layer as if you had x-ray vision and looking through the top to the bottom.
Here's the same layer mirrored. As the traces would look when look at the bottom of the board.
You can power the board with 5V at any one of the three "VIN" positions.
But what is that robot doing in your front yard? (Hint. Not an erco design.)
Which robot in my front yard?
Got me. He just arrived there after dragging an issue footlocker twice his size and walking all the way from the middle east. He might answer to the name "Scooby Doo!"
So the one I bought from them originally for a PI hat, originally idea obscured by time, now finds a newer reason. The board schematics that you provided @"Duane Degn" will still provide a use because it make things easier for me to wire the camera board to the whole business.
Uh oh, now the robot has opened the footlocker and he's busy unpacking another one like himself.
