That helps alot. I suspected no cognew, but people were still posting code on this thread that uses cognew() - and the conversion table didn't really cover it.
I became confused.
I downloaded & read the 4 pages of Tricks, Traps & Differences thread, and some Conversion documentation from Rayman.
But as I mentioned - assembly language is difficult for me.
Since the internal clock is set at 20 Mhz, is there a way to use the external multiplier (320 Mhz) & pin I/O - to emulate a rudimentary ALU for faster calculations?
instead of: cog := cognew(@PWM_Asm, @command) use: cog := coginit(16, @PWM_Asm, @command)
16 means the first free cog is allocated, you can also start a specific cog if you use 0..7 instead of 16.There are threads abut the difference between Spin1 and Spin2.
I became confused.
Thank you for the assistance.
Mask long 1<<0, 1<<1, 1<<2, 1<<3, 1<<4, 1<<5, 1<<6, 1<<7 long 1<<8, 1<<9, 1<<10, 1<<11, 1<<12, 1<<13 ...
