SPIN and the Scott Edwards serial input LCD.
denno
I was wondering if anyone would be willing to share some SPIN code to use with the 4 X 20 Scott Edwards LCD's which use only SERIAL in. I have done it with various Basic Stamps with SEROUT but need a little help with the Propeller..something simple...LOL
But, I was wondering how I would do it using STRING in SPIN...thank you
TASK LCD_1 LMM 'this TASK is running in COG 7 '========[PIN ASSIGNMENTS]======== LCD_data_out PIN 2 '========[VARIABLES]=========================== VOLT VAR LONG VOLTtenth VAR LONG VOLThunds VAR LONG VOLT_12v VAR LONG VOLTtenth_12v VAR LONG VOLThunds_12v VAR LONG MCPValue VAR LONG TEMP_100 VAR LONG TEMP_10 VAR LONG TEMP_tenths VAR LONG inDistance VAR LONG rawHeadingAve VAR LONG target_dist VAR LONG target_tenth VAR LONG '======================================================================= 'the following DATA statments are to preload the display, the variables are loaded elsewhere in the program. LCD_data_0 DATA clrLCD,backLTon PAUSE 100 LCD_data_1 DATA posCMD,64,"LDis=",posCMD,74,"TEMP=",0 'LCD...line 1 LCD_data_2 DATA posCMD,84,"COMPASS=",posCMD,95,degreeSYM,posCMD,100,"IN'S",0 'LCD...line 2 LCD_data_3 DATA posCMD,104,"VOLTAGE=",posCMD,115,".",posCMD,119,"volts",0 LCD_data_4 DATA posCMD,124,"VOLTAGE=",posCMD,135,".",posCMD,139,"volts",0 SEROUT LCD_data_out, baud, LCD_data_0 'clear the screen, beeb, and turn on the back light SEROUT LCD_data_out, baud, LCD_data_1 'to print line 1 SEROUT LCD_data_out, baud, LCD_data_2 'to print line 2 SEROUT LCD_data_out, baud, LCD_data_3 'to print line 3 SEROUT LCD_data_out, baud, LCD_data_4 'to print line 4 DO ' A LONG DIATANCE MEASUREMENT RDLONG longDistance, target_dist 'reading the distance data that is in the HUB PAUSE 50 RDLONG longDistance_tenth, target_tenth PAUSE 50 ' IF target_dist < 100 THEN ' SEROUT LCD_data_out, baud, beep ' ENDIF LCD_data_1a DATA posCMD,69," ",0 LCD_data_1a(2) = STR target_dist,3,5 SEROUT LCD_data_out, baud, LCD_data_1a ' A COMPASSS ANGLE MEASUREMENT and DISTANCE MEASUREMENT RDLONG compassDegrees, rawHeadingAve PAUSE 50 'reading the temperature data that is in the HUB RDLONG distanceLocation, inDistance PAUSE 50 LCD_data_2a DATA posCMD,92," ",posCMD,96," ",0 'to clear previous readings LCD_data_2a(2) = STR rawHeadingAve,3,5 LCD_data_2a(7) = STR inDistance,3,5 SEROUT LCD_data_out, baud, LCD_data_2a ' THIS IS A READING FROM A VARAIBLE 5 VOLT RDLONG volt_location, VOLT 'reading the voltage data that is in the HUB PAUSE 50'100 RDLONG tenth_location, VOLTtenth 'reading the voltage data that is in the HUB PAUSE 50'100 RDLONG hunds_location, VOLThunds 'reading the voltage data that is in the HUB PAUSE 50'100 ' THIS IS A READING FROM A LM34 RDLONG temp_location_100, TEMP_100 PAUSE 50'100 RDLONG temp_locationTenths, TEMP_tenths PAUSE 50'100 LCD_data_1aa DATA posCMD,79," ",posCMD,81,".",posCMD,82," ",posCMD,83,degreeSYM,0 LCD_data_1aa(2) = STR TEMP_100,2,5 LCD_data_1aa(9) = STR TEMP_tenths,1,5 SEROUT LCD_data_out, baud, LCD_data_1aa LCD_data_3a DATA posCMD,114," ",posCMD,116," ",posCMD,117," ",0 LCD_data_3a(2) = STR VOLT,1,5 LCD_data_3a(5) = STR VOLTtenth,1,5 LCD_data_3a(8) = STR VOLThunds,1,5 SEROUT LCD_data_out, baud, LCD_data_3a ' THIS IS A VOLTAGE MEASUREMENT OF INCOMING SUPPLY VOLTAGE RDLONG volt_location_12v, VOLT_12v PAUSE 50'100 RDLONG tenth_location_12v, VOLTtenth_12v PAUSE 50'100 RDLONG hunds_location_12v, VOLThunds_12v PAUSE 50'100 RDLONG MCPValueLocation, MCPValue PAUSE 50 ' IF MCPValue < 9426 THEN '9828/819 = 12.00 volts...beep warning ' SEROUT LCD_data_out, baud, beep ' PAUSE 100 ' ENDIF LCD_data_4a DATA posCMD,133," ",posCMD,136," ",posCMD,137," ",0 LCD_data_4a(2) = STR VOLT_12v,2,5 LCD_data_4a(6) = STR VOLTtenth_12v,1,5 LCD_data_4a(9) = STR VOLThunds_12v,1,5 SEROUT LCD_data_out, baud, LCD_data_4a LOOP ENDTASK '''LCD_1
