Paralleling MOSFETs
The neighbor and I were noodling (danger!). He is an instrumentation guru at one of the local hydrocarbon processing sites. He needs to weld thin type K thermocouples out of raw wire stock. A LOT of thermocouples. Quickly. We goofed around with a 100 amp 6 volt supply and got some fair spot welds pressing them in an X formation between copper electrodes, so now we are looking to produce a bunch and achieve better time/volts/current control.
My thought is to use a simple MOSFET driver circuit controlled by a P1. It will take several MOSFETs paralleled to handle the high currents involved.
Question: Do MOSFETs in parallel inherently current share when their gates are driven hard? Or do they act more like traditional transistors where you have to mess with individual emitter resistors to keep the currents balanced? I suppose I could just try it, but I already spend a lot of time dealing with that pesky purple smoke.
Current sharing will still depend on the RDS variations, and on the parasitic wiring milli-ohms to each FET.
On a spot-welder, you would also need to worry about possible avalanche energy so you may be better to design a sync converter buck regulator (ie a MOSFET in each possible current path)
6V/100A is 60 mOhms, and you can buy MOSFETS well under 2m Ohms these days, Digikey has 829 hits < 1.2mOhms, so you may decide to ask 20-30A per MOSFET as a practical wiring operate point ?
Yeah, I sort of think 20-something amps is about the realistic limit per MOSFET and that will be imposed by the physics of copper traces on FRB. BTW: I saw a really gauche (but effective) setup made by a guy making a solenoid “gun”. He dead-bugged a dozen MOSFETs onto two parallel copper rails and tied the gates together. It was ugly as sin, but the leads were short and apparently it worked well. I may have to explore this option just for fun.
The charging circuit can be a low current affair that charges to a precise voltage and doesn't get stressed over super precise timing or crazy spikes. Could even use a multi-pole relay here for isolation before discharge.
http://www.dcccorporation.com/hotspotplus.html
As a trigger, an SCR might be preferable to the MOSFET. Dump the energy, auto reset. It is not hard to find an SCR that can handle the voltage and a surge current of well over 100A.
Energy stored, E = C*V^2 / 2
20000µF charged to 50 volts give 25 watt-seconds. (=joules).
That is sufficient for smaller (<20 gauge) thermocouples.
The high end hotspotplus claims to deliver maximum 525 watt-seconds for 12 gauge couples and general spot welding.
Thanks for this!
I wonder about that too. If you play the video from the link above to the hotSpot welder, or look at the capacitive discharge welders from Omega Engineering TL-WELD-Series, it looks like the arc weld is indeed initiated when you touch the wires to the big carbon electrode while holding down an "enable" switch. The capacitor is directly connected to the two sides of the contact point and there is no FET or SCR or relay in series to initiate the discharge event. Both of them use an insulated long-nose plier connected to the power to hold the wires. (have to be careful with up to 80 volts?!) The Omega device holds the touch electrode in a well inside the instrument and allows for an optional argon purge, but the DCC device uses an external block of carbon or whatever. There is probably a transistor involved in the charging process while you wait for the green light to come on between events.
Just a quick update and a word of appreciation for all the feedback:
We hit a bit of a wall yesterday using capacitive discharge to fuse the thermo's. It works a treat mechanically now, but the resulting thermocouples are not even close to spec outputs. They are all over the map with no discernable pattern except they all read low.
There are two working theories for this at present:
1). There is contamination either from the atmosphere or from the copper contacts of the weld jig, or,
2). Something is happening to the wire during the weld process that causes there to be more than one point of generation.
So for the moment we are forced by time constraints to fall-back to a quick buzz from the TIG torch in an inert atmosphere.
I'm going to keep noodling at this because it intrigues me, and I'll follow up with findings when they come.
Thanks to one and all for your insights!
EDIT: Tracy posted while I was writing this. That bit about the optional purge gas sort of confirms this could be a consideration. Thanks, @"Tracy Allen"
https://youtube.com/watch?v=-8cBCjJJcB4
Note one if the comments regarding twists and the reply.
I've tried it DIY with mixed success using old motor brushes or carbon poles pulled from old C-Zn D cells, hooked to a lab supply. It does take patience to find the optimal energy/wire mix.
