PLX-DAQ TIME and DATE at the same time issue
Serial.println("DATA,DATE,TIME,");
Using an Arduino Uno.I am having issues with the second value after the directive DATA.
Using the code above the output into my spread sheet is Column A: 7/29/2020 Column B: 0.79
If I swap them so TIME is the first value and DATE the second I get Column A: 7:11:19 PM Column B: 44041.00
If I delete either the DATE or the TIME all the rest works fine.
Here's the other relevant code in case I am unknowingly causing the problem somewhere else.
Serial.begin(9600);
Serial.println("CLEARDATA");
Serial.println("LABEL,Date,Time,House,Shed,PUMP STATUS,PUMP CYCLES");
Serial.println("RESETTIMER");
Serial.print("DATA,DATE,TIME,");
Serial.print(HouseOutputValue);
Serial.print(",");
Serial.print(ShedOutputValue);
Serial.print(",");
if(PumpStatus == HIGH){
Serial.print("ON");
}else{
Serial.print("OFF");}
Serial.print(",");
Serial.println(PumpCycles);
Thanks for any help. I realize this an old unsupported software.
https://www.parallax.com/downloads/plx-daq
The problem was a simple column format issue.
