PropGCC program to use with telnet - help
in Propeller 1
The program below is not working as expected. When it first starts up, I get a lot of garbage characters. When I type in 'help', I get the menu, but I also get an 'Invalid Command' after that. Not sure why that is occurring. Is the menu() somehow sending a garbage character after the subroutine runs?
I tested this with Putty and Tera Term, and I get similar results. Anybody have any suggestions as to what is going on.
Ray
Ray
flip_telnet.c
June 23, 2020
#include "simpletools.h"
#include "simpletext.h"
#include "fdserial.h"
serial *telnet;
void crMenu();
int main()
// Add startup code here.
//char inBuff[40];
int inBuff;
telnet = fdserial_open(31, 30, 0, 115200);
//print("Type 'help' to see system menu.\n");
writeStr(telnet,"Type 'help' to see the system menu.\n");
while(1)
// Add main loop code here.
writeStr(telnet,"> ");
//print("> ");
readStr(telnet,inBuff,sizeof(inBuff));
//getStr(inBuff,40);
if(!strcmp(inBuff,"help"))
crMenu();
else
writeStr(telnet,"Invalid Command!\n");
//print("Invalid Command!\n");
//inBuff = 0;
//pause(500);
void crMenu()
writeStr(telnet,"\n System Menu\n");
writeStr(telnet,"help - Show the System Menu.\n");
//print(" System Menu\n");
//print("help - Show the system menu.\n");
Telnet terminal
#H¾gáJl=Ö,®rRi_^úñm¼ôZ»Aô&ëype 'help' to see the system menu.
helplp
System Menu
Invalid Command!
Ray
In my simple program, it seems that the terminal programs are not interpreting the 'else' part correctly. It looks like when I type in 'help', it does the crMenu() function, as expected, and then it does the 'else' also. I am expecting that when the 'help' part is processed it is supposed to bypass the 'else' part. I could be wrong about this.
Ray
What I am doing is a print("%s\n,inBuff") and I have the simpleide terminal window opened up. In the simpleide terminal window I see what was typed in on the Tera Term window. This is getting to be complicated just test this out.
Ray
In Tera Term, it has a Terminal Setup window, and that contains some choices for "New-line". The Receive - CR, CR+LF,LF,AUTO. The Transmit - CR,CR+LF,LF.
I had the Transmit set to "CR+LF", so, I guess when I hit "enter" on the keyboard it was sending a CR+LF. I thought that readStr() needed a CR+LF, but I guess all it needs is either a CR or an LF.
Now with Putty I did not see that kind of Setup window, and I think it sends a CR+LF when the "enter" key is keyed.
That was some subtle stuff that had to be worked out. In this particular case it seems that readStr() works correctly with either a CR or an LF.
Ray
In the Settings for the WX module I did not notice anything that addresses that, maybe like an always responsive choice. The cure, so far is to power off the WX module and then power on the module.
Ray
So far I tried out Tera Term, Putty, and Windows telnet. The Tera Term program, once you make the correct settings, seems to work OK. Putty and Windows telnet have CR+LF tied to the "enter" key, which does not work as expected.
The WX WiFi SIP module, is still a mystery, as to why it is becoming unresponsive to the terminal programs, after being idle for some time. I guess nobody from Parallax is reading this thread to propose a solution.
For a solution to the CR+LF, I was thinking probably that the readStr() function should be improved to provide some kind of parsing or manipulation of the input string to make readStr() work as expected.
Now to see what else trips up readStr(), the WX SIP module, or even the FLiP module.
Ray
/* flip_telnet.c June 23, 2020 */ #include "simpletools.h" #include "simpletext.h" #include "fdserial.h" serial *telnet; void crMenu(); int main() { // Add startup code here. char inBuff[20]; telnet = fdserial_open(31, 30, 0, 115200); writeStr(telnet,"Type 'help' to see the system menu.\n"); while(1) { // Add main loop code here. writeStr(telnet,"> "); readStr(telnet,inBuff,20); if(!strcmp(inBuff,"help")) { crMenu(); } else { writeStr(telnet,"Invalid Command!\n"); } pause(500); } } void crMenu() { writeStr(telnet,"\n System Menu\n"); writeStr(telnet,"help - Show the System Menu.\n"); }
Something like this:
void strip_trailing(char *str) { char *ptr = str+strlen(str); while(*--ptr <= 0x20 && ptr >= str) *ptr = 0; }
The source for the readStr function is in Learn/Simple Libraries/TextDevices/libsimpletext files getStr.c and safe_gets.c. As far as I can tell (haven't tested) it doesn't handle LF correctly: when you type a string it ends the loop with CR however LF is still in the receive buffer so when readStr is called again it ends immediately returning en empty string, so you have an alternance of typed/empty strings when CR/LF is enabled.
The problem with telnet is probably due to it sending a NUL character (0x00) after each line, so after the first typed string, the first character it puts on the buffer is a NUL, which is a string terminator, and all your comparisons fails. You can easily verify this if you print a hex dump of your string buffer after readStr, after the first string you should see \0 H E L P \0 every time.
Unfortunately I don't think there is way to prevent telnet from sending that NUL (I think putty does the same) but it can be easily filtered from safe_gets by adding an if before (*buf++) = ch so it adds only printable characters (ch >= 32 && ch <= 127). Or you can try ExtraPutty that has some additional settings.
Hope this helps.
Best regards,
Marco
