(resolved) instruction question
Seairth
@cgracey, note these two entries in the spreadsheet:
NOT D,{#}S {WC/WZ/WCZ} EEEE 0110001 CZI DDDDDDDDD SSSSSSSSS Get !S into D. D = !S. C = !S[31]. *
NOT D {WC/WZ/WCZ} EEEE 0110001 CZ0 DDDDDDDDD DDDDDDDDD Get !D into D. D = !D. C = !D[31]. *
In the first entry, is the "#" required for S? In other words, should it be:
NOT D,#S {WC/WZ/WCZ} EEEE 0110001 CZ1 DDDDDDDDD SSSSSSSSS Get !S into D. D = !S. C = !S[31]. *
Or is the {#} a mistake and this instruction actually re-purposes the immediate flag to switch between S and D registers for the second operand? In which case, this would be correct:
NOT D,S {WC/WZ/WCZ} EEEE 0110001 CZ1 DDDDDDDDD SSSSSSSSS Get !S into D. D = !S. C = !S[31]. *
EDIT: Never mind. I wasn't thinking about this clearly, obviously.
The original instructions are correct. It's just that the aliased version is the equivalent of doing "NOT D, D". While I guess you could also do "NOT D, #D", it wouldn't make much sense.
Andy
