upcoming fastspin changes
ersmith
There are some major changes coming to fastspin, and apply both toe Propeller 1 (P1) and Propeller 2 (P2). They're in the current github, and I'll put a binary up for my Patreons soon. The big new features are:
(1) Ability to place functions in COG memory (and eventually LUT memory on P2), e.g. we could write in the various languages
(2) FCACHE is now enabled by default for P2. This is a feature where small loops are copied to processor internal memory (LUT in the case of P2) before execution. This feature was already present on P1 and enabled at level -O2 for P2; now it's enabled at level -O1 (the default) for P2 as well.
(3) ORG/END blocks on inline assembly are loaded into FCACHE memory before execution. A similar feature is available in C (with "__asm volatile") and BASIC ("asm cpu").
(4) The symbol name resolution has been revised, so that symbol resolution takes place in the language of the file associated with the object. So Spin symbols will be case insensitive, even for references from C, and C symbols are case sensitive even for references from Spin (and non-lower case C symbols can be accessed now).
There are probably going to be many bugs associated with these new features, but if you'd like to try them out I'd encourage you to do so. Note that the Makefile dependencies don't seem to be quite right, and for this change (which hits some key internal files) you should do "make clean" before trying to build the new version.
' Spin1 / Spin2
pub {++cog} sum(x, y) : r
r := x+y
' BASIC function for "cog" sum(x, y) return x+y end function
// C
int sum(int x, int y) __attribute__(("cog")) {
return x+y;
Obviously this will have to be used sparingly!(2) FCACHE is now enabled by default for P2. This is a feature where small loops are copied to processor internal memory (LUT in the case of P2) before execution. This feature was already present on P1 and enabled at level -O2 for P2; now it's enabled at level -O1 (the default) for P2 as well.
I wanted to report a problem with a warning message. I tend to use the 4-port serial driver for the P1. This sets up coroutines to handle the various optional features of the serial ports and FastSpin seems to choke on the JMPRET instructions used for this. Is there a way to turn off the warning? The warning messages tend to terminate my build scripts.
The warnings can be fixed by following the direction in the warning, e.g changing "jmpret rxcode,txcode" to "jmpret rxcode,txcode+0" (or "txcode-0", or any expression at all really... although now that I think about it perhaps "txcode-0" is better, in analogy to 0-0).
Another way to fix the warnings would be to change the first 8 instructions from things like: to In this case fastspin will notice that the jump target is data, rather than code, and hence be happy with its use in an indirect jump.
Thanks for this code example, Mike.
so in more recent versions I've used
jmpret receive, 0-0
with the appropriate ddd field and so on for all 12 instances. The way the patches are done, only the serial ports that have been enabled are included, and others that are not enabled are locked out.
Was the error thrown by the process of patching the jmpret's, or by fact that the jmprets point to instructions? The Prop2 doesn't have a jmpret, does it?
As to the initial 9 locations that are used as the vectors, any of the forms will work, so long as they get the initial targets into the source field. The if_never is unnecessary, as any of the following will work. They all function the same way, so it is an aesthetic preference.
Placing the vector locations at the top of the cog is an unnecessary trick. Program operation does not depend on it, and they can be placed in a more conventional manner at the end of the code. However, having them at the beginning makes it easier in a way to visualize the action. Both the source and dest fields of all the jmpret instructions have numbers from 0 to 8 to indicate which vector is used as the program detects data and jumps around through the coroutines.
There is no if-never condition. It is used for the _RET_ condition.
A long may not necessarily be a NOP, but execute whatever bits are there. IIRC it’s something like a ROL 0,0 that is treated as a NOP.
Sorry. Thought it was a P2 thread I was reading. Must have been asleep at the wheel.
if_always is the default
Sorry ersmith, I don't want to derail this thread.
I downloaded FlexGUI and tried to compile a P1 program that uses GPS_IO_mini, and the compiler throws an error about two lines using this symbol: <>=
Propeller tool compiles it fine
I attach the object
Massimo
Thanks for the bug report. is another way of writing
Fastspin should have accepted the first form but didn't. I'll fix that bug; but I suspect actually that the original code was meant to read since Rx is set immediately afterwards, there's no need to update it.
I agree, the assignment is useless.
Anyway it's kind of funny the first compile threw the error. I guess it's a seldom used command :-)
Thanks again,
Massimo
