My Gripper 3 stopped working
in Accessories
After playing with it a while the gripper just froze. Could not move it at all.
After taking it apart I discovered that the shaft had small burrs on it that must have broken off inside the shaft causing the gear to bind and no longer turn.
Due to the tight tolerances the shaft no longer fits.
Now my fingers are black from playing with the aluminum.
Need to polish the burrs off the shaft so I can put it back together.
I'm going to need to find something to polish the two surfaces to remove the scratches. I don't want to use sand paper as that seems to be too ruff.
I use Scotch Brite on steel to remove burrs. Don't know if it too abrasive for aluminum.
Pics are worth, well you know.
https://learn.parallax.com/tutorials/gripper-30-assembly-instructions/gripper-bill-materials
The problem is that the base shaft started to lose particles of aluminum that ground into the shaft of the arm causing the two to bind together to the point where neither one would move anymore. They became inseparable. After some work I managed to get the two apart so I could clean them.
After cleaning them the two no longer fit. There where small burrs inside the hole.
I used a metal piece and tried to smooth the burrs out. After working on it I then applied some grease to the shafts and was able to put them back together. They now work perfectly.
The instruction don't really say to put grease on the shafts but I see now that is really a good idea if you plan to use them for any amount of time.
When I was working with breast biopsy probes, the glue fixtures would slowly accumulate excess super glue which we would scrape off periodically.
Eventually the bare aluminum started to show especially along the edges of the inner radiuses.
I pulled off all those parts and had then stripped and Hard anodized but I forgot to specify the color so the black parts can back a dark gray.
We should be specifying some grease on that shaft component, but we don't introduce the grease until later than it is needed. We will adjust that in the assembly documentation.
iseries, please send your shipping info kgracey@parallax.com and I'll get some replacement parts off to you.
I'll be interested in knowing if others have the same problem, in which case we will adjust the assembly, substitute materials, or add anodizing. For certain, we should specify grease earlier in the process.
Sorry we caused this trouble for you, too.
No need for replacement parts. I was just surprised when the two pieces bonded together.
Just applied a small amount of grease and it worked like new. I have been playing with it on my desk like a fidget spinner for days now and still works like new.
We're good on the offer, even if you take me up on it later.
This is an easy issue to fix. Either undersize the shafts or oversize the holes they fit in, and provide users with thin-wall PTFE tube that they can cut to length. The interface between the aluminum and PTFE will remain slick without having to apply grease.
Here's a link to McMaster-Carr's selection of PTFE tube:
https://www.mcmaster.com/ptfe-tubing/sleeving-4/
Nylon or Delrin spacers are another option if you can find one with a thin-enough wall. In any event, it's my opinion that aluminum-on-aluminum will continue to be a problem long-term, regardless of whatever lubrication is applied. A clockmaker once told me that the best and least troublesome interfaces between moving parts are those made of dissimilar materials.
Another option is to replace the machined shafts with steel shoulder screws; but those can get kind of expensive, since you'd need six of them.
I would also drop the two screws that fit on the Idler gear as it is held in place by the two end screws.
I guess the real challenge would be to attach a servo to the part and flex it 1000 times which is far more than any use this item will get on any robot installation.
See how many cycles you can run it through before the grease wears down. Hook it up to a bench power supply and let it grab itself to death. . .
We could use the data! If you don't, I shall - maybe tomorrow!
