Can Scott Edwards Mini SSC be programmed with Parallax?
in BASIC Stamp
Hey I'm new to this platform, any help is appreciated.
I have a Scott Edwards Mini SSC II for servo motor control.
Can I program this module using the Parallax BASIC Stamp IDE?
Thanks in advance!
Thanks in advance!
These serial commands can come from a BasicStamp or other device with a UART capable of 2400bps.
To use control the SSC using the Parallax BASIC Stamp IDE you'd also need a Basic Stamp in order to use the SSC. You'd use the Parallax BASIC Stamp IDE to program the Basic Stamp which in turn would control the SSC. The Parallax BASIC Stamp IDE can't directly control or program the Mini SSC.
