QuickStart Touchpad Tutorial demo for PROPGCC
mindrobots
This is a propgcc port of the SPIN only version of the Quickstart button demo by JonnyMac from this thread:
http://forums.parallax.com/showthread.php?132048-QuickStart-module&p=1007660&viewfull=1#post1007660
Nothing exciting but we need simple examples for tutorial purposes. It could probably be trimmed down a bit but I didn't want to lose the essence of how the touchpads worked.
It exhibits the same flicker and instability issues most of the touchpad demos do.
Beau Schwabe's Sigma-Delta might be my next victim of porting. It's a very nice implementation of "sticky buttons".
// file = QS_padscan.c
// propgcc conversion of JonnyMac's SPIN version of Quickstart Button Demo
// simple propgcc tutorial demo
// copyright 2011 by Rick Post
// terms of use below
#include <propeller.h>
int scan_pads(long int delay)
OUTA |= 0x000000ff; // "charge" the pads - force them HIGH
DIRA |= 0x000000ff; // set them as output
DIRA &= 0xffffff00; // release touch pads back to input
waitcnt(delay+CNT); // delay for a "touch"
// a touched pad goes to LOW
// so if you invert the input bits you can mask them out
// and return the "touched" pads as HIGHS
return ((~INA) & 0x000000ff); // return the touched pads
int main(void)
int pads = 0;
DIRA |= 0x00ff0000; // set LEDs for output and pads for input
DIRA &= 0xffffff00;
while (1)
pads = scan_pads(CLKFREQ / 100); // scan the pads passing delay to wait for user touch
pads = pads << 16; // shift the pad pins (0..7) to the LED pins (16..23)
OUTA &= 0xff00ffff; // clear out the scanned pads from last time
OUTA |= pads; // set the most recent scanned pads
return(0);
TERMS OF USE: MIT License
Permission is hereby granted, free of charge, to any person obtaining
a copy of this software and associated documentation files
(the "Software"), to deal in the Software without restriction,
including without limitation the rights to use, copy, modify, merge,
publish, distribute, sublicense, and/or sell copies of the Software,
and to permit persons to whom the Software is furnished to do so,
subject to the following conditions:
The above copyright notice and this permission notice shall be
included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
I ran into the same button problems. There is a way to "debounce" the pads.
This is what I used. It's a port of the code on the ParallaxSemiconductor web site.
int getButtons() { int n = 16; int result = -1; int reading = 0; int pins = 0xFF; OUTA |= pins; //output high to buttons while(n--) { DIRA |= pins; //output high to buttons DIRA ^= pins; //switch to input reading = pins; msleep(2); //wait for RC time reading &= INA; //return button states result &= reading; } result = ~result & 0xFF; return result; }Works well for me. I'd also like to see this in the library distribution if it meets the "standard. . . " whatever that is. I don't know what good C code looks, but I can identify well-written Spin and PBASIC. I see a fair amount of similarity between the C and Spin.
The comments are really helpful for me and I appreciate them.
Great project. Simple. Want to buy a Mac just to blink LEDs on a Propeller now, but I'll just pretend.
i would like to understand where does the n=16 come from ?
is it because of the debounce ? if so why 16 ?
32 bit binary representation of 2 buttons being pressed (buttons 16 & 17) scan_pads returns pads var as: 31 0 b00000000_00000000_00000000_00000011 after pads = pads << 16, pads looks like: pins 17 & 16----|| || vv b00000000_00000011_00000000_00000000dgately
but on the code posted above by @jazzed
int getButtons() { int n = 16; int result = -1; int reading = 0; int pins = 0xFF; OUTA |= pins; //output high to buttons while(n--) { DIRA |= pins; //output high to buttons DIRA ^= pins; //switch to input reading = pins; msleep(2); //wait for RC time reading &= INA; //return button states result &= reading; } result = ~result & 0xFF; return result; }There's a loop of 16 that i don't understand.
