Can a 4-pin HC-SR04 ultrasonic sensor be used on the parallax board, i.e. with PropellerC?
in Robotics
I assume so.
Is there a tutorial or description.
I have an activitybot and have it working with the Parallax 3-pin sensor.
I had purchased two more sensors for use with an Arduino board I was going to try with some projects I have in mind.
I am working with my son on a maze solving robot and would like to connect three sensors.
Thanks for any help
dakotaknut
I assume so.
Thanks for any help
dakotaknut
Welcome to the forums! Yes, you can use those sensors with an Activity board. The PING is a much higher quality unit, but we've all been tempted by those $1 HC-SR04s. Like the PING shown at http://learn.parallax.com/activitybot/build-and-test-ping-sensor-circuit, you'll power it with 5V and use two resistors to interface to the 3.3V Propeller.
The four pin HC-SR04 has seperate TRIGger and ECHO pins, requiring two Prop I/O pins. BUT... there is a top secret, insider-exclusive, eyes-only, password-protected, secret-handshake-required, simple one-resistor modification to make it function on just one I/O pin. See this long-winded thread with lots of juicy info: http://forums.parallax.com/discussion/comment/1301893/#Comment_1301893
https://gist.github.com/flakas/3294829#file-hc-sr04-ino-L82
There are some build problems
Serial.begin doesn't work, but I don't think I need it
OUTPUT, LOW, and HIGH are all problems.
The example didn't show the header file I would need.
I am looking for examples of the use of these.
For example pinMode([pin], OUTOUT);
and digitalwrite([pin], LOW);
LOW and HIGH are undoubtedly as simple as 0 and 1.
I recollect seeing OUTPUT in an example sometime back when I was working on this a little bit.
I would like to use a header file for these. I assume that would be the best.
Thank you
I can't wait to take a look at this.
#include "simpletools.h" /* HC-SR04 Sensor https://www.dealextreme.com/p/hc-sr04-ultrasonic-sensor-distance-measuring-module-133696 This sketch reads a HC-SR04 ultrasonic rangefinder and returns the distance to the closest object in range. To do this, it sends a pulse to the sensor to initiate a reading, then listens for a pulse to return. The length of the returning pulse is proportional to the distance of the object from the sensor. The circuit: * VCC connection of the sensor attached to +5V * GND connection of the sensor attached to ground * TRIG connection of the sensor attached to digital pin 14 * ECHO connection of the sensor attached to digital pin 15 Original code for Ping))) example was created by David A. Mellis Adapted for HC-SR04 by Tautvidas Sipavicius This example code is in the public domain. */ const int trigPin = 14; const int echoPin = 15; int main() { while(1) { // The sensor is triggered by a HIGH pulse of 10 or more microseconds. // Give a short LOW pulse beforehand to ensure a clean HIGH pulse: low(trigPin); pulse_out(trigPin, 10); // Read the signal from the sensor: a HIGH pulse whose // duration is the time (in microseconds) from the sending // of the ping to the reception of its echo off of an object. long tEcho = pulse_in(echoPin, 1); // convert the time into a distance int inDist = tEcho / 148; int cmDist = tEcho / 58; print("%d inch\n", inDist); print("%d cm\n", cmDist); pause(200); } }
