Spin2 OBJ declaration in FlexGUI
JonTitus
in Propeller 2
Brand new to the Propeller 2 and its SPIN2 programming but I have programmed the Propeller 1 with SPIN. I have loaded the FlexGUI and I see in a spin2 example the notation:
What does the
obj ser: "spin/SmartSerial"
What does the
spin/portion of the declaration indicate? Thanks.
' ' Charlieplex-driver demo. ' Connect LED MATRIX accessory board to 12-pin male header marked with P32 through P39. ' Uses objects: ' charlieplex_test.spin2 from C:.. flexgui414b\flexgui\samples\LED_Matrix ' SmartSerial from C:.. flexgui414b\flexgui\include\spin ' CON _clkfreq = 180_000_000 obj charlie : "charlieplex_text.spin2" 'LED control ser : "spin/SmartSerial" 'Serial I/O in .../include/spin/ folder pub main | i ' Use i as a local variable ser.start(63, 62, 0, 230_400) 'Serial pins, setting, bit rate ser.str(string("Charlieplex demo", 13, 10)) 'Send text to Propeller terminal i := charlie.start 'Start LED Charlie-multiplex, get next-cog value ser.str(string("Started cog ")) 'Send text to terminal ser.dec(i-1) 'Send cog number to terminal ser.str(string(13, 10, "saying hello...")) 'Send text to terminal charlie.str(string("Hello, world! and:")) 'Send message to LED-display object ser.str(string(" saying goodbye...")) 'Send text to terminal charlie.str(string("Goodbye?")) 'Send message to LED-display object repeat 'Repeat this instruction forever ' Program Charlieplex-driver demo ends.I'll update the version in the next distribution.
