How to run a program with the Spin2 Interpreter — Parallax Forums
If I compile the Spin2 Interpreter and load it into ram, how do I get it to run a Spin2 program?
John Abshier
  • cgraceycgracey Posts: 14,293
    You would need to make a little bytecode program to append to the end of it. If you just run PNut and write some Spin2 code, it's a lot easier.
    I thought I had to load the spin2 interpreter and went looking for how to do it.
    Then I looked at Chips' VGA example and the interpreter was nowhere to be found in it.
    So I ran the VGA code and it just worked. pnut handles the spin2 interpreter automatically - you don't need to worry about the spin2 interpreter :smiley:
