Spin2 - Conversion from P1 Spin to P2 Spin2 - discussion and questions — Parallax Forums
Just trying to understand what is required for converting some routines...
PUB readByte                    ' returns a byte
  readData(@result, 1)
--becomes--------------------------------------------------------------
PUB readByte() : ch             ' returns a byte (actually it returns a long)
  ch := readData(@result, 1)
Is result still defined in spin2???
PUB readString(stringPointer, maximumStringLength)
  if(stringPointer and (maximumStringLength > 0))
    result := stringPointer
    bytefill(stringPointer--, 0, maximumStringLength--)
    repeat while(maximumStringLength--)
      ifnot( readData(++stringPointer, 1) and byte[stringPointer] and (byte[stringPointer] <> 10) and (byte[stringPointer] <> 13) )
        quit
PUB readString(stringPointer, maximumStringLength) : result
  result := 0
        quit
I have presumed here that result is no pre-initialised to 0, so I must explicitly do this now.
I realise this is not the most efficient, as it would be faster to use if ... else return:=0
PUB writeData(addressToGet, count) | stride
  result := addressToGet
  if(lockFileSystem("W") and fileOpenCloseFlag and fileReadWriteFlag)
    count := ((count <# (posx - currentPosition)) #> 0)
    repeat while(count)
      if(((currentPosition >> 9) > currentSector) and fileBlockDirtyFlag)
        fileBlockDirtyFlag := false
        readWriteCurrentSector("W")
      currentByte := currentPosition
      ifnot(readWriteCurrentCluster("W"))
        quit
      stride := (count <# (512 - currentByteInSector))
      bytemove(addressDIREntry, addressToGet, stride)
      currentPosition += stride
      addressToGet += stride
      count -= stride
      currentSize #>= currentPosition
      fileBlockDirtyFlag := true
  unlockFileSystem
  return (addressToGet - result)
PUB writeData(addressToGet, count) : result | stride
    repeat while(count)
        quit
      count -= stride
  unlockFileSystem
  result := (addressToGet - result)
Again, I presume we don't have result so I need to declare it, and the return needs to become a result := (addressToGet - result)
In the case above, what happens with the quit statement?
None of this takes the abort into account which I'll have to deal with later.
  • cgraceycgracey Posts: 14,289
    Their is no automatic RESULT variable in methods. Any result value must be given a symbolic name, for their to be any return value(s). It is not necessary to use that name, however, if you do a 'RETURN resultvalue'.
    ABORT is a little different. It always returns ONE value, regardless of the number of return values in a method.
    Plain ABORT without an argument returns 0, while 'ABORT value' returns 'value'.
    Thanks Chip.
    That makes it easier. Just have to ensure I preset the result to 0 first.
    All results are preset to 0, so no need to initialize return values in case they aren't ever assigned anything.
    edited 2020-04-04 04:46
    So these would be the first rules for spin1 to spin2 conversion...
    Note: Spin1 has a limit of a single long returned. Using this as a basis...
    1. If there is no "(" following (ie no calling parameters) then PUB/PRI requires "()" following it. Spaces allowed.
    2. If the PUB/PRI returns a value, then the PUB/PRI needs the inclusion after the ")" of " : result"
    3. There is no default set for result. Therefore, if a default result of zero is required, then the line result := 0 must be inserted as the first statement. Code improvement can be done later.
    4. Single statements of method(params) that actually return a result need to be converted to result := method(params)
  • JonnyMacJonnyMac Posts: 9,623
    edited 2020-04-04 06:27
    No. In the P1, the implicit result variable is initialized to zero. In the P2, explicit return variables are also initialized to zero.
    Other changes:
    -- P2 methods can return multiple values (all must be declared)
    -- P2 local variables can be longs (default), words (must be declared by type), or bytes (must be declared by type)
    JonnyMac wrote: »
    Thanks Jon. I didn't know the P2 initialised them to zero, so I can remove that item :)
    Other changes:
    Yes, but currently I am only concerned with porting spin1 to spin2. Since these features were not available in spin1 they currently don't matter.
    edited 2020-04-04 15:21
    I mention that because I have Spin1 code that looks like this:
    pub some_method(param1, param2, paramN, p_var1, p_var2)
    ...where p_var1 and p_var2 are pointers to variables that I want updated by the method. Also, there are times -- I've found, anyway -- when a local byte array is convenient; the ability to type P2 locals makes this easier and gets rid of the variable.byte[n] syntax. It's a small thing, but clearer to newcomers, I think.
    edited 2020-04-04 18:43
    JonnyMac wrote: »
    Yes, I have passed a pointer to an array where I’ve used and updated variables in that array. It’s perhaps more common too. Certainly passing a pointer to a list of known parameters is quite common - eg a set of parameters for a list of pins, or a set of vga parameters.
    Of course these will still work as-is in spin2.
