how do i generate random numbers in an interval?
in Propeller 1
Hi,
Title says all. I know the ? operator but I have no idea how to put it to practical use. Spin doesn't have a random function like I'm used to with other languages so I have no idea how and what to do with "?". Any help would be greatly appreciated.
Cheers!
Cheers!
http://obex.parallax.com/object/498
It will return a random number between lo and hi - 1.
Are you sure that's correct? Don't you need to strip the sign bit before the // in case the result of ?seed is negative? Otherwise, it will return numbers in the range (lo-(hi-lo+1), hi).
is there a way to randomize numbers from 1 to 70?
In the post above there is discussion about the randomize() method from the attached object. It would go like this:
rval := prng.randomize(1, 70)
Easy peasy.
Hi
I wonder if you are asking for all the numbers 1 to 70 to be in a randomised order since getting a random number between 1 and 70 has already been explained.
If that is the case then build an array with the numbers 1 to 70 in it and starting at array item 1, exchange it with another number in the array, range 1-70 generated using the randomise function, and work your way through the whole array.
Dave
