Help converting OBEX object to C
                                  in Propeller 1
                    I am not really a C guy but I am attempting to convert a timer spin object to C.  I am stuck on this line of code, spin2cpp cant even do it correctly as it wont run as converted by spin2cpp.
The spin code line is :
Any insight is much appreciated!
okay := cogon := (cog := cognew(updateTimerDown, @tmrStack)) > 0
#include <propeller.h> unsigned int okay = 0; unsigned int cogon = 0; int cog; long tmrStack; int updateTimerDown(); int main (void) { //EDIT '&' okay = cogon = (cog = cognew(&updateTimerDown, &tmrStack)) > 0; // okay and cogon will equal 1 (a boolean "true") if the cog was created successfully // cog will equal the created cog number } // EDIT void updateTimerDown(void *par) { }dgately
#include "simpletools.h" void updateTimerDown(void*); int ok; int cogon; int tmStack; main () { tmStack = 40; ok = cogon = (cog = cog_run(&updateTimerDown, tmStack) > 0; } void updateTimerDown(void *par) { while (1) { cog code } }cogs do not return a value and run continuously.
Here is the code
timer.cpp
#include "timer_countdown.h" #include "simpletools.h" timer_countdown timer; int main() { char* time; print("starting up\n"); timer.Start(); print("Object Started\n"); timer.Set(0,1,5); print("Timer Set\n"); timer.Run(); while(1) time = timer.Showtimer(); print (time); }timer_countdown.h
#ifndef timer_Plus_countdown_Class_Defined__ #define timer_Plus_countdown_Class_Defined__ #include <stdint.h> #include <stdio.h> #include <string.h> class timer_countdown { public: static const int TIX_DLY = 100; static const int MAX_STR = 16; static const int TMR_TIX = 0; static const int TMR_SECS = 1; static const int TMR_MINS = 2; static const int TMR_HRS = 3; static const int TMR_DAYS = 4; int Start(void); int Stop(void); int Set(int H, int M, int S); int Reset(void); int Hold(void); int Run(void); int Rdreg(int Reg); int Wrreg(int Reg, int Value); char* Showtimer(void); private: unsigned int cogon, cog; char tmrstack[12]; int tix, scs, mns, hrs, dys; int running; char tmrstr[MAX_STR + 1]; int Updatetimer(void); }; #endiftimer_countdown.cpp
#include <simpletools.h> #include "timer_countdown.h" int timer_countdown::Start(void) { int okay; Stop(); Reset(); okay = cogon = (cog = cognew(Updatetimer(),&tmrstack)) > 0; return okay; } int timer_countdown::Stop(void) { if (cogon > -1) { cogstop(cog); } return 0; } int timer_countdown::Set(int h, int m, int s) { Hold(); tix = (dys = 0); scs = (abs(s)); mns = (abs(m)); hrs = (abs(h)); return 0; } int timer_countdown::Reset(void) { Hold(); tix = (scs = (mns = (hrs = (dys = 0)))); return 0; } int timer_countdown::Hold(void) { running = 0; return 0; } int timer_countdown::Run(void) { running = -1; return 0; } int timer_countdown::Rdreg(int reg) { int result = 0; if (reg == TMR_TIX) { result = tix; } else if (reg == TMR_SECS) { result = scs; } else if (reg == TMR_MINS) { result = mns; } else if (reg == TMR_HRS) { result = hrs; } else if (reg == TMR_DAYS) { result = dys; } return result; } int timer_countdown::Wrreg(int reg, int value) { if (reg == TMR_TIX) { tix = ((abs(value)) % 100); } else if (reg == TMR_SECS) { scs = ((abs(value)) % 60); } else if (reg == TMR_MINS) { mns = ((abs(value)) % 60); } else if (reg == TMR_HRS) { scs = ((abs(value)) % 24); } else if (reg == TMR_DAYS) { dys = (abs(value)); } return 0; } char* timer_countdown::Showtimer(void) { int t, s, m, h; t = tix; s = scs; m = mns; h = hrs; memset( (void *)&tmrstr, 0, 1*((MAX_STR + 1))); tmrstr[0] = ((h / 10) + '0'); tmrstr[1] = ((h % 10) + '0'); tmrstr[2] = ':'; tmrstr[3] = ((m / 10) + '0'); tmrstr[4] = ((m % 10) + '0'); tmrstr[5] = ':'; tmrstr[6] = ((s / 10) + '0'); tmrstr[7] = ((s % 10) + '0'); tmrstr[8] = '.'; tmrstr[9] = ((t / 10) + '0'); tmrstr[10] = ((t % 10) + '0'); return tmrstr; } int timer_countdown::Updatetimer(void) { tix = 99; while (1) { if (running) { waitcnt(((CLKFREQ / TIX_DLY) + CNT)); tix = (--tix); if (tix == 0) { tix = 100; (scs--); if ((scs == 0) && (mns > 0)) { scs = 60; (mns--); if ((mns == 0) && (hrs > 0)) { mns = 59; (hrs--); if (hrs == 0) { (dys--); } } } if ((scs == 0) && (mns == 0)) { Reset(); } } } } return 0; }timer_countdown.cpp:9:25: error: lvalue required as unary '&' operand
timer.start() does not return. It appears to lock up when called.
timer.c
/* Blank Simple Project.c http://learn.parallax.com/propeller-c-tutorials */ #include "simpletools.h" // Include simple tools #include "timer_countdown.h" int main() // Main function { // Add startup code here. char* time; countdown_start(); countdown_set(0,1,5); countdown_run(); while(1) { // Add main loop code here. time = countdown_showtimer(); print (time); print("\n"); waitcnt(((CLKFREQ / TIX_DLY) + CNT)); } }timer_countdown.h
timer_countdown.c
#include "timer_countdown.h" #include "simpletools.h" int countdown_start(void) { int okay; countdown_stop(); countdown_reset(); okay = cogon = (cog = cognew(&countdown_updatetimer, tmrstack)) > 0; return okay; } int countdown_stop(void) { if (cogon > -1) { cogstop(cog); } return 0; } int countdown_set(int h, int m, int s) { countdown_hold(); tix = (dys = 0); scs = (abs(s)); mns = (abs(m)); hrs = (abs(h)); return 0; } int countdown_reset(void) { countdown_hold(); tix = (scs = (mns = (hrs = (dys = 0)))); return 0; } int countdown_hold(void) { running = 0; return 0; } int countdown_run(void) { running = -1; return 0; } int countdown_rdreg(int reg) { int result = 0; if (reg == TMR_TIX) { result = tix; } else if (reg == TMR_SECS) { result = scs; } else if (reg == TMR_MINS) { result = mns; } else if (reg == TMR_HRS) { result = hrs; } else if (reg == TMR_DAYS) { result = dys; } return result; } int countdown_wrreg(int reg, int value) { if (reg == TMR_TIX) { tix = ((abs(value)) % 100); } else if (reg == TMR_SECS) { scs = ((abs(value)) % 60); } else if (reg == TMR_MINS) { mns = ((abs(value)) % 60); } else if (reg == TMR_HRS) { scs = ((abs(value)) % 24); } else if (reg == TMR_DAYS) { dys = (abs(value)); } return 0; } char* countdown_showtimer(void) { int t, s, m, h; t = tix; s = scs; m = mns; h = hrs; memset(&tmrstr, 0, 1*((MAX_STR + 1))); tmrstr[0] = ((h / 10) + '0'); tmrstr[1] = ((h % 10) + '0'); tmrstr[2] = ':'; tmrstr[3] = ((m / 10) + '0'); tmrstr[4] = ((m % 10) + '0'); tmrstr[5] = ':'; tmrstr[6] = ((s / 10) + '0'); tmrstr[7] = ((s % 10) + '0'); tmrstr[8] = '.'; tmrstr[9] = ((t / 10) + '0'); tmrstr[10] = ((t % 10) + '0'); return &tmrstr; } void countdown_updatetimer(void *par) { tix = 99; while (1) { if (running) { waitcnt(((CLKFREQ / TIX_DLY) + CNT)); tix = (--tix); if (tix == 0) { tix = 100; (scs--); if ((scs == 0) && (mns > 0)) { scs = 60; (mns--); if ((mns == 0) && (hrs > 0)) { mns = 59; (hrs--); if (hrs == 0) { (dys--); } } } if ((scs == 0) && (mns == 0)) { countdown_reset(); } } } } }Mike
Enjoy!
Change it to the following:
You can use print function in a cog because it violates the pin rule but you can set pins high and low to see where it is.
also the function pause(1000) can be used to delay 1 second.
One more thing your returning a point that is already a pointer...
