How to declare an unsigned 16-bit variable in Prop GCC?
I have the following table in my C code:
Even though the compiler accepts positive constants like 65535, it treats them as negative numbers later in my program. I want them to be treated as unsigned. How do I do it? (Prop GCC does not recognize ushort.)
short _sigmoid[257] = {
0, 17, 34, 51, 70, 89, 109, 129, 151, 173, 196, 220, 246, 272, 299, 327,
357, 387, 419, 452, 486, 522, 559, 598, 638, 680, 723, 768, 815, 864, 914, 967,
1022, 1078, 1137, 1199, 1262, 1328, 1397, 1468, 1543, 1619, 1699, 1782, 1868, 1958, 2050, 2147,
2246, 2350, 2457, 2569, 2685, 2804, 2929, 3057, 3191, 3329, 3473, 3621, 3775, 3934, 4099, 4270,
4447, 4630, 4819, 5014, 5217, 5426, 5642, 5865, 6096, 6334, 6580, 6834, 7096, 7366, 7645, 7932,
8228, 8532, 8846, 9169, 9501, 9843,10194,10555,10926,11307,11697,12098,12509,12930,13361,13802,
14254,14716,15188,15670,16162,16664,17176,17697,18228,18769,19319,19877,20445,21021,21605,22197,
22797,23404,24018,24638,25264,25896,26534,27176,27823,28473,29127,29783,30442,31103,31765,32428,
33091,33754,34416,35077,35736,36393,37047,37697,38343,38986,39623,40255,40882,41502,42116,42723,
43322,43914,44499,45074,45642,46201,46750,47291,47822,48344,48856,49358,49850,50332,50804,51265,
51717,52158,52590,53011,53421,53822,54213,54593,54964,55325,55676,56018,56350,56673,56987,57292,
57588,57875,58153,58423,58685,58939,59185,59423,59654,59877,60094,60303,60505,60701,60890,61073,
61249,61420,61585,61744,61898,62047,62190,62328,62462,62591,62715,62835,62951,63062,63169,63273,
63373,63469,63562,63651,63737,63820,63900,63977,64051,64122,64191,64257,64321,64382,64441,64498,
64552,64605,64656,64704,64751,64796,64840,64881,64922,64960,64997,65033,65067,65100,65132,65163,
65192,65221,65248,65274,65299,65323,65346,65369,65390,65411,65431,65450,65468,65486,65503,65519,
65535
uint16_t _sigmoid[257] = {... OR unsigned short _sigmoid[257] = {... OR unsigned short int _sigmoid[257] = {...
typedef uint16_t word;
