Problem With Local Bytes
JonnyMac
in Propeller 2
While working on my I2C routines, I did this test
If I change to this:
@cgracey Is the a problem with PNut? I'm using v34n.
pub main() | device, addr, slaveid, last, byte s, m, h
setup()
' write 23:59:45 to rtc
s := $45
m := $59
h := $23
i2c.start()
i2c.write($D0)
i2c.write($00)
i2c.wr_block(@s, 3)
i2c.stop()
last := -1
repeat
i2c.start()
i2c.write($D0)
i2c.write($00)
i2c.start()
i2c.write($D1)
s := i2c.read(i2c.ACK)
m := i2c.read(i2c.ACK)
h := i2c.read(i2c.NAK)
i2c.stop()
if (s <> last)
term.tx(term.HOME)
term.fstr3(string("%2.2x:%2.2x:%2.2x"), h, m, s)
last := s
waitms(50)
Only the seconds and minutes are written to the clock -- hours gets 0.If I change to this:
pub main() | device, addr, slaveid, last, time, byte s, m, h
setup()
time := $23_59_45
i2c.start()
i2c.write($D0)
i2c.write($00)
i2c.wr_block(@time, 3)
i2c.stop()
last := -1
repeat
i2c.start()
i2c.write($D0)
i2c.write($00)
i2c.start()
i2c.write($D1)
i2c.stop()
if (s <> last)
term.tx(term.HOME)
last := s
waitms(50)
...the complete time is correctly written to the RTC. The only difference is using a local long vs local bytes.@cgracey Is the a problem with PNut? I'm using v34n.
Edit: I just did a little test to confirm that the size override must be done per variable. In my original version m and h were longs.
In Spin2 the default size for locals can be overridden.
That is interesting...
