Spin2 - Page 18 — Parallax Forums
Spin2
1121314151618»
  • RaymanRayman Posts: 16,199
    edited 2020-02-16 16:23
    Roy Eltham wrote: »
    Eric's compiler produces PASM to be run in hubexec. It's a whole different animal compared to how Chip's compiler works.
    Actually, I suppose Spin2 would have to produce PASM meant to run in hubexec in a dat section with assembly instructions following an "ORGH", right?
    Since that is something new, maybe there's room for a middle ground? Maybe this kind of code could resolve absolute addresses, same way in Spin2 and FastSpin?
  • @Rayman
    Chip's SPIN2 is interpreted bytecode, while Fastspin is compiled.
    Have you read Chip's code for the interpreter? It's not particularly long.
    The interpreter is split between cog and hub.
    AJL, Spin2 can also launch assembly cogs using "coginit".
    Those cogs can presumable call hubexec assembly code....
  • Rayman wrote: »
    Perhaps I misunderstood your original comment, or I'm nit-picking.
    While PNut is the current tool to produce SPIN2 code, Chip's aim is for SPIN2 to be self-hosted; PNut produces PASM code for execution, SPIN2 currently does not.
    Given SPIN2 is interpreted, then any assembly cogs would have their code produced by some other tool, e.g. PNut, or a self-hosted PASM2 Assembler.
    I am going to work tomorrow on the documentation. That will clear the air quite a bit.
  • Rayman wrote: »
    Sorry, one more thing... Is there a list of the Spin2 operators somewhere?
    I thought that "=>" was going to change to ">=", like C++, but I think Fastspin didn't make this change, so I wonder about Spin2...
    Also, I'm getting an error on this:
    value := ||(value+x)
    So, I think absolute value operator has changed...
    I found the 2018 proposed operators here: https://forums.parallax.com/discussion/166416/spin2-operator-syntax/p17
    Seems || is now ABS...
    @cgracey
    I have been looking for the spin2 command list in the forums. Complete list as is complete at this time. Can you point me in that direction please.
    Martin
    Martin, this is the latest documentation which lists all Spin2 commands:
    https://docs.google.com/document/d/16qVkmA6Co5fUNKJHF6pBfGfDupuRwDtf-wyieh_fbqw/edit?usp=sharing
    There are some DEBUG-displays-related things that are not documented, yet. I am working on a simplified syntax for the DEBUG displays. When that is done, which may be tomorrow, I will post a new zip file and bring the documentation up to date.
  • @cgracey
    Thanks for the assist.
  • @cgracey
    Perfect again thanks.
