Can The Project Board Be Modified To Allow WiFi Programming Like The Propeller Activity Board WX?
in Propeller 1
I would like to modify a Propeller Project Board to allow WiFi programming like the Propeller Activity Board WX, however I am uncertain about the complexity or the simplicity of such an undertaking. I have been reviewing the Propeller Activity Board WX Schematic (https://parallax.com/sites/default/files/downloads/32912-Propeller-Activity-Board-WX-Schematic-Rev-B-and-C.pdf), but more particularly page 2 of this document, and it does appear that some of the circuitry could be eliminated, such as the circuitry for the LED's.
I would just purchase a Propeller Activity Board WX, but I need the through hole prototyping area. I assume it can be done, but I am wondering about the absolute necessities.
https://www.parallax.com/product/32999
They plug into the Propeller Activity Board WX, so breadboard becomes protoboard.
I think if you needed multiple different protoboard circuits, or wanted to experiment with a few circuit options, then the PAB-WX + Circuit Overlay becomes a pretty handy and resource friendly combination. Much cheaper to stock up on Circuit Overlay boards than entire protoboards.
Every thing is there 3.3v GND, Tx, Rx and even Reset if you want to do remote code load.
XBee Adapter Board
@iseries - As mentioned in my last thread, I already have the Propeller Project Board USB and Parallax WX ESP8266 WiFi Module - SIP. My current goal is to solder the WiFi Module to the protoboard, wire up the absolute necessities like VIN, GND, DO, and DI, which makes it usable. From that point, I want to make it so that I do not have to rely on USB for programming the Propeller, but instead, program it using the WiFi connection.
The Parallax WiFi work just like a Prop Plug. You just plug it in and it works. I did not use any special inverter or circuits.
the propeller mini comes w/o usb and uses a propplug, cool.
I thought Parallax does not make any boards w/o usb anymore.
As stated often the mandatory FTDI on the boards even drove me to use a hacksaw to remove USB from my Project boards, weld in a 4 pin header and gain another propplug, when rescuing the cut out FTDI.
Thanks @"Duane Degn" for the tip...
Okay, let me step back for a minute. As mentioned, my intentions are to use the WiFi module with a Project Board, however I am currently testing with a Propeller Board of Education USB.
With the WiFi module plugged into the breadboard area of the BOE, I can currently load and run programs using USB, however if I disconnect the USB and use the WiFi port for loading the program, the loading fails.
It is noteworthy to mention that I have DI and DO hooked up to pins P8 and P9. Are you using pins P30 and P31?
If so, I wonder if the BOE or Project Board has any special circuitry that would prevent me from hooking up to these pins. I certainly do not want to short anything.
EEPROM is 28/29 but that does not matter P1 needs 30/31.
So what to do? bypass FTDI on your board. I am talking about attaching in-between P1 and onboard FTDI.
first you need ground and power for the WiFy module
the TX(on propeller) and RX on FTDI are not a problem, you can just listen, directly connecting your WiFy RX to either pin(P1 or FTDI).
I think /RTS(/DTR) is also ok to simply connect directly.
The problematic line is TX from FTDI to Propeller, Propeller is fine, just listening.
But FTDI drives that pin and your WiFy module wants to drive it also.
There is the conflict you asked for.
I am not good at electronics, my solution would be to cut the trace and solder some jumper there to connect either WiFy TX or FTDI TX to P1 RX.
Maybe two diodes could do the trick, I simply don't know
In the long run, I imagine that I will need a custom board to achieve my goals.
I have put a lot of thought into your suggestion and I must admit that the idea has grown on me. After doing some testing and working on a few issues with iseries help, I do believe that I will be purchasing a Propeller Activity Board WX, another WX ESP8266 WiFi Module (DIP configuration this time around), and several Circuit Overlay Boards.
I now believe this is probably the best overall solution for what I am trying to achieve.
@Everyone else
I sincerely thank you for your input.
I don't know if you recall this Wixel thread or not, but I've used a pair of Wixels to wireless program propellers. I don't think the Wixels are as elegant of a solution as the one you're hoping for but if you wanted to try the Wixel approach, I could send you a pair (I have a couple I could spare).
I haven't used this technique in a while and I haven't tested these with Windows 10 yet.
Either way, good luck on your project.
I hope all is well with you and yours.
At this point, I have all of my programming for the WiFi module written, to match the functionality of my current USB programming, with the exception of programming the EEROM by WiFi. All I need now is the previous items mentioned, and then I will be able to experiment more and expand upon the current programming by adding bluetooth capability.
Anyhow, I truly appreciate the offer, and thanks for reaching out to lend a helping hand.
I see that you are slowly but surely participating a bit more in the forums lately. It is good to know that you have not jumped ship
Bruce
Anyway most of the functionality that you are using is done as well as the web pages and file system. I have not started working on the Bluetooth though and don't know how I would make that work at this point.
I have been working with BLE 5 to see how it all works and this look very interesting but complicated as compared to straight Bluetooth. You get a headache trying to think about services, characteristics and GUIDs.
Now if you have something that wants to publish some information I could use this as a blue print to see how one would build the services. So we would need a code to build the service and then the characteristics and finally reveal the values.
Just a thought.
PS. I do not have remote code loading working and don't know how to make that work.
@VonSzarvas - Thank you for pointing me in a good direction. If necessary, I can have a board made with the same form factor as the overlay boards. At this point, it is certainly the best way for me to go. SD card ready, wireless programming ready, documentation available, etc... And I can make it look very professional by having a board made with the same form factor as the overlays. No one will know the difference by opening the enclosure, unless they are an EE. It will make my product more expensive, but it will have functionality.
@iseries _ Without disclosing too much about my current project, it is specifically all about motor control. It is only one stepper motor, but a webpage controls how this motor functions. For now, we will call it the user interface. There are many options available to the user, and when the user makes their selection of options, it formats a 3`5 charachter long string, and writes it to a file on a web server (but it could also be locally hosted). The WiFi module accesses this file on the internet and tells the motor exactly what to do, according to user selections and the format of the string from these selections.
I currently believe that I can achieve all the functionality that I want, just with the WiFi module, but just in case, I ordered the Bluetooth module, because I want to be able control the motor with a cellular phone. I have not delved into that part of the project just yet, but I will, just as soon as I test my new code with my latest purchases. It will be very cool to be able to wirelessly program a stepper motors running chacteristics on the fly
Big thumbs up for Making Stuff Happen!
