Washer Dryer Detector
iseries
I have an idea for a project, a washer dryer detector.
Like most homes there washer dryer are in the basement. You go down there and put your laundry in them and wait for them to beep right. Well it’s like the tree that falls in the forest. Does it make a sound?
What if we made a tone detector that listens for the two different beeps and sends out an alert. It could be like an Alexa skill where you could say “hay Alexa tell me when the washer or dryer are done” and it response with “OK”. Or you could have an app on your phone that sends you an alert that your dryer is done and if it’s connected to your activity tracker or smart watch your wrist would buzz.
Now the problem is you forgot you put the laundry in and you’re at the mall shopping, oppose.
We could have Ken make an info commercial and sell them for 3 easy payments of 19.95, no wait for a limited time get two units for the same price just pay shipping and handling. We could call it the Clap on Clap off for the washer dryer. Ok maybe we need someone more upbeat then Ken.
We have most of the hardware needed except a way to detect the beeps coming from the washer dryer. You could wire something into the washer dryer but that would mean taking it apart and messing with the wiring and every washer dryer is different so that might not be a good idea.
So we need like a telephone encoder that can take sound and convert it to an 8 bit value that we can process. From there we use a Parallax WiFi module to connect it to our network and send out an alert that is picked up by an app. They always have an app for that right.
So the question is how to detect the beeps if no ones in the basement since it might not make any noise.
PS: we could also add in a water detector so when things overflow. I have one of those things that you set on the floor and it beeps when it detects water.
On a serious note, how about using a passive (inductive) amp-clamp? When the current falls to near zero, the washer/dryer is done. Have two channels: 1=washer, 2=dryer. Maybe add an option for a couple of SSR's for controlling other stuff too.
I rigged up a vibration sensor using one axis of a 3-axis accelerometer. When less than a certain amount of movement is detected by a propeller chip (because the drum is no longer rotating), and for more than 45 seconds or so, I sound a buzzer.
It's not even mounted to the dryer, it just sits on top.
It would probably also work for a washing machine, as long as the delay allowed for the pauses between cycles.
Works pretty well, but at this time it's not sensitive enough, so it sounds off even though the dryer is still going. I just need to tweak my settings.
I'm not sure about the washer, but the dryer should be detectable by a whole house power meter. Some energy meters can recognize appliances by their energy usage patterns. I don't know first hand how well that works.
Since my cellphone is always with me I use it to time washing machine, dryer, oven, microwave, and anything else I need to time, including rise and shine if a specific time is required.
I do just remember that I have to move stuff from washer to dryer or dryer to inside. Heck they rarely take more then half/full hour.
Honestly, you need a phone/ringer to remember what you did half a hour ago?
confused,
Anyway they show the time on the front of them but it's never right. Both units could say they have a minute left and then run for about 20 to 30 minutes. They have all kinds of sensors now and do all kinds of gyrations to get the job done.
So no, you can't set a timer and then just check on them.
The idea is to listen for the beeps and trigger an app to let you know they are done and you need to move those paints and shirt if you don't want them wrinkled and have to iron them.
The washer, probably not, at least for ones like mine with mechanical controls.
But for dryers, the type of load does affect the running time. A load with many towels will take much longer to dry than one with just shirts, for example.
For me it's not so much a matter of remembering what I did half an hour ago, it's being so focused on what I am working on that loose complete track of time. My wife used to swear that a demolition crew could tear the house down around me and I wouldn't notice unless part of it fell on my bench.
A voice recognition systems seems to be a bit of overkill to me. An audio band pass filter tuned for the base frequency of the buzzer would be much simpler, and connecting two wires to the buzzer and making use of that signal even simpler.
They output 24 bits of frequency but I fear that the Propeller chip may not be fast enough to handle the conversion. The specs say it needs a 3.072 MHZ frequency to drive the clock.
This is the chip I'm looking at Invensense ICS-43432.
Building an I2S driver sounds like fun.
