P2 SD card code test... — Parallax Forums
Cluso99Cluso99 Posts: 18,071
edited 2020-01-03 04:17 in Propeller 2
Attached is a test program for SD Cards. I would appreciate testing this on your SDHC cards formatted as FAT32.
I compiled it with FlexGUI v4.0.6 and downloaded it with LoadP2 v4.0.6 using the windoze command prompt window/program.
It runs on the P2-EVAL Rev B with Rev B silicon and RevA with RevA silicon. (All switches OFF)
It should run on the P2D2 Rev A provided a 10K pullup resistor is connected to pin 25 as it self-identifies the P2-EVAL and P2D2.
It runs at 160MHz.
Below is a sample of the expected output. There is a further debug that can be enabled for SD cards that fail the test (see line 497 of the spin code).
I am particularly interested that SDHC cards are detected (the program will error is you use an old card that uses byte mode addressing), and
That the SD-DO pin reports as being Hi.
Your dump of the sector will be different!
The checkpoints are just prior to that command being sent to the SD card.
    The routines...
    Initialise
    ReadCSDCID
    ReadSector
    WriteSector
    are all callable. At the end of each of these, the pins are tristated, and a successful result is NC and Z.
    I have these routines almost ready to replace the PASM code drivers that we used in P1 where it ran in its own cog. Kye’s spin code will need converting tho.
  • blew the dust of my P2A and download the flexgui code. Compiled and ran the code. Got nothing.
    edited 2020-01-03 11:34
    Did the download work?
    Once loaded and running the first thing it does is initialise the serial port and output the P2-EVAL or P2D2 message and this occurs before the SD card code runs.
    I presume you don’t have anything connected to P25?
    I just power my board from the USB port (the serial port) as my PC supplies power just fine.
    I’ll post the little bat file i use to compile and load and run tomorrow.
  • I think the key is to make sure to use the -SINGLE option when loading this binary (-CHIP was not successful in providing output)...
    Results from my P2-EVAL Rev B:
    My python load script does this:
    return_code = subprocess.call("loadp2 -p /dev/cu.usbserial-DN43WMDD -b 115200 -l 115200 -t -SINGLE " + fn, she$
    dgately
    602 x 620 - 487K
    Thanks.
    Yes, you need the -SINGLE option.
    What may not have been obvious from my screenshot is that f406 is flexgui v4.0.6 renamed and similarly l406 is loadp2.
  • Your test program seems to run fine here on my Rev B board with two different SDHC cards (an 8 GB Sony and a 16 GB nextech).
    BTW, the reason that loadp2 -CHIP doesn't work is that there's a typo in the loadp2 fast loader code which causes all of memory to be erased at load time, including the debug area (it was not supposed to touch memory above $7c000, but it does). You can avoid this by passing -NOZERO to loadp2, or, obviously, -SINGLE.
    I hadn't realized that -SINGLE doesn't clear RAM but apparently it doesn't -- in the course of testing this I wrote a little program to poke data into HUB and it persists across loads with -SINGLE.
  • evanhevanh Posts: 17,020
    Oh, I think I'd prefer -CHIP to not clear hubRAM by default, same as -SINGLE. If a program wants hubRAM cleared then it can do so itself.
  • I tried this from FlexGui 4.0.6 but there is something weird going on
    Without an SD card loaded, it runs with passes various checkpoints, null data
    ( Entering terminal mode.  Press Ctrl-] to exit. )
       Auto Detected P2EVAL
    Initialise
    Checkpoint 0
    Checkpoint 0
    Checkpoint 0
    Checkpoint 0
    Checkpoint 0
    Checkpoint 0
    Checkpoint 0
    Checkpoint 0
    Checkpoint 0
    Checkpoint 0
    ***error*** 00000040
    When I put a Sandisk Ultra 16GB card in the slot, it doesn't run.
    SD204.binary failed to load
    Error response was ""
    Press enter to continue...
    There may be a .bix on the card that takes it down a different path?? Should that matter?
  • I later tried a 64 G samsung that seemed to work, so maybe its just that card or something on it.
    Note I have formatted some of my cards with non default cluster sizes
  • Tubular wrote: »
    I would think that if it boots from the card then it won't be possible to load anything via serial, which would explain the "binary failed to load" message.
  • Yeah I think you're right. I'll dig deeper but it might be on Monday
    It will not work if there is a boot program on the SD (_BOOT_P2.BIX or .BIY or in the boot sector 0 or VOL).
    Checkpoint is not a "PASS" but rather that will now be tested, Your card failed the very first command (checkpoint 0 = command 0).
    Of course, since there is no SD card, it will fail command 0. Perhaps I need to check for pullup on SD_CS (from the card). I don't need to do this in the ROM because when I get passed control from Chip's booter he has already confirmed that there is a pullup (ie a card).
    Different cluster sizes should be fine.
    edited 2020-01-04 14:52
    This is my F.BAT file for assembling P2 code
    F406.exe is fastspin.exe v4.0.6 renamed
    L406.exe is loadp2.exe v4.0.6 renamed
    f406 %1.spin -2 -l
    l406 %1.binary -b115200 -t -SINGLE
    Note that I call my .spin2 files .spin as I still edit with PropTool.
  • Flexgui still does not work. I type: flexgui SD204.spin -2 -1
    I get "Error in startup scrip".
    To load the binary I used bin\loadp2 SD204.binary -b115200 -t -SINGLE
    program completes normally and works just fine.
    Initialise
    Checkpoint 0
    Checkpoint 8
    Checkpoint 55
    Checkpoint 41
    Checkpoint 55
    Checkpoint 41
    Checkpoint 55
    Checkpoint 41
    Checkpoint 55
    Checkpoint 41
    Checkpoint 55
    Checkpoint 41
    Checkpoint 55
    Checkpoint 41
    Checkpoint 58
    Checkpoint 16
    SD-DO pin high
    Success
    SDHC card
    Read CSD+CID
    Checkpoint 9
    Checkpoint 10
    SD-DO pin high
    Success
    Read sector
    Checkpoint 17
    SD-DO pin high
  • iseries wrote: »
    I think @Cluso99 mistyped; he meant "fastspin" rather than "flexgui". flexgui is the graphical interface; fastspin is the actual compiler. Also, that second argument is probably a lower case L rather than the digit 1 (not sure from the font which you typed). It's the fastspin flag to produce a listing file and is optional anyway, only the "-2" (for P2 output) really matters.
    Sorry, yes it’s fastspin :(
  • Great, just trying to get this to work for those that may want to try it on there own.
    You will also notice the autodetection of P2-EVAL vs P2D2 which must have a pullup on P25 (and nothing on P2-EVAL P25)
  • Cluso99 wrote: »
    The P2D2 doesn't have any pull-ups on any ports under P56 where P56,57 are I2C. There must be a better way to check for hardware and so detecting pullups on these two pins might help.
    edited 2020-01-05 01:48
    Peter,
    I added the pullup on P25 because it was easy to plug a pullup resistor into my P2D2 as i have female pins on my board. IIRC 3V3 is 0.3 or 0.4” away from P25 making it easy to plug in a pullup.
    I couldnt see any other easy way to do an auto test.
