Remodeling shop, seeking ideas on security cameras, wiring etc...
W9GFO
My shop has been mostly emptied into a 26ft storage container so that I can rip out some extraneous walls and put in some insulation and sheet rock. Pictured below is what it looked like after filling the container.
I have a few hundred feet of Cat 5e and Cat 6 (Rg-6 too), I am planning to use the Cat 5e for some POE security cameras and the Cat 6 for computers and other devices. The longest run should be under 50 ft.
I would appreciate some recommendations on POE cameras - it feels like there is an infinite number of models/brands that I have never heard of. I suppose if I want to someday put in a fancy 4K PTZ, I should run the Cat 6 for that - but that would be in addition to three or four fixed cameras - which I hope would be content with the Cat 5e.
Now is the time to run the wiring in the ceiling and the walls, before they are insulated and covered up. Any other ideas on what to put in them?
Unless you are in danger of being spooked, wifi is fine IMHO. At work we use CAT5 because we are in an Office building and wifi is not so fast when shifting 1GB+ video files around. Wifi suffers if there are lots of wifi users on separate networks nearby with lots of use, as they share common channels.
I used ABS Sever lines, because you have all the connectors, cleanouts and covers you need.
This way you can add wires later on when needed, say you decide to put some sound system there or need some low voltage wire for a door lock, you know something you are NOT thinking off right now.
You also should think about putting some waterproof outlets on the outside walls, way more easy then running a conduit around the house. (That one I missed doing and regret it now)
Same goes for outside Lights, even just run the wires, switches and buy the lights later.
But once it is closed up you do not want to mess with it again.
CYA. If there is work that would have required permitting and it was not applied for and inspected, three very unpleseant things can result. 1) You go to sell the house and the inspection finds unpermitted work, sale goes on hold or lost until corrected. Also refer to third consequence. 2) you have a fire maybe not really related to the work, but maybe, you insurance company tells you to pound sand and you fight them for a few years before maybe they pay out. Oh, yes, number three may apply as well. 3) locality finds out somehow. First you get the fines and then you get to rip it all out and then do it all again with the appropriate permitting.
Paranoid? Admittedly so, but still enjoying my hot for the last few years. No issues to worry about from any source down the road.
Don't use WiFi for security cameras, Cat5 is just fine even at 4K you are unlikely to go above 50MB/s and H.265 is becoming more common so that will go down in the future.
If you have Cat6 to hand then I would use that, almost all installations we do these days are Cat6, probably been that way for 2 years now.
As for camera manufacturers, we use Axis, BOSCH and Hanwah Wisenet (formerly Samsung) and we don't use any Chinese manufacturers at all.
They cost more but you get what you pay for.
A large retail store deployment we did this year was professionally penetration tested and the company that did it threw up some advisory notices on the Axis camera Linux kernels.
Within 2 weeks of notifying Axis they had new firmware that addressed all the issues for every camera in their range, that's worth paying a little extra for....
I am more interested in reliable intruder detection.
I just received this TOF sensor to play with.
Good point. Best intrusion detector to use is the pir/microwave unit imho. Having cameras in a few locations would also help. Hard wired systems are better than WiFi/BT. A single cat5/6 cable can connect to several smart sensors to power the sensor and connect it to the main alarm panel.
At my office we use a mix of Arlo wireless and Samsung POE cameras, because the office cat just isnt much of a threat these days. A tripping hazard maybe. When the Arlo’s age-out, I’m going back to the POE cameras. They just work. The Arlo’s are kind of a toy... not so much a serious tool for security. The new POE cameras have an amazing picture.
We've used those to sense people moving in an indoor fluoro lit area. They work great, better than ultrasonics
Oh cool. I have read good reviews. Don't suppose the driver is in the OBEX?
My memory is that he started looking at the longer range version but the registers were quite different and don't think that went anywhere
The 4m ones we used were on an Arduino based platform. They worked impressively well, however
For quick experimentation, Parallax have a ready-to-go version called LaserPING. Drivers are available in Blockly and Spin. (It uses the same driver as the original Ping, and also has a serial interface option. Easy to interface with PropBasic too!)
https://www.parallax.com/product/28041
(Apologies W9GFO for veering OT)
Same problem that we discussed not too long ago.
Lots of us on this side of the pond would love to be sourcing more stuff from Parallax but unless Digikey stocks it....
There must be a simple solution because I have purchased from @Cluso99 and other retailers in OZ and the shipping cost has been negligible and the import tax has been zero.
It's not just a China thing.
Amazon or Mouser.eu
There's a bunch of other distros too, if you google LaserPing.
I take your point though, more generally.
This is the one I have.
