Help finding capacitor kit
I have a dilemma on my hands. I own zero capacitors and I cannot even use my ne555 timer due to this. So, I jump onto Amazon and look for a capacitor kit. I find electrolytic caps in the range I want (0.1uf to 100uf), but I cannot find the same for 3.3v-5v ceramic caps. I would like to get a kit of ceramic caps rather than electrolytic caps, due to the fact that electrolytic caps dry out. I require caps which will operate in the 3.3v to 5v range and are rated from 0.1uf to 100uf. Can anyone help in this endeavor?
You also need to read up on the ceramic types. 1pf-1nF are often disc ceramics in t/hole, although caps used in oscillator circuits tend to be NPO these days.
For 100nF-10uF you should try and get MONO X7R or X5R ratings - definately not the cheaper Z5U.
Disc ceramics are those round orange/brown ones and have gone out of favor, compared to the monolithics.
I'll leave you to do the research why
Yes, 16V caps work fine in a 5V circuit.
You might buy things you did not really need, but...
Anyways try https://www.banggood.com on your risk of your own sanity. Delivery takes a while but up to now I have no complains.
Enjoy!
If you are going to use th caps then there is no reason not to use electrolytics for the 10uf up range because they work, they are cheap, and they don't just dry out unless you use them in power supply filtering with high ripple currents and too close to hot regulators. If you are that worried, which you shouldn't be, use tantalums instead but even PC motherboards use e-caps.
I’ll just get a kit of electrolytic caps. From what you guys say, they aren’t all that bad, so I’ll take it.
That scare was going around well over a decade ago and only applied to manufacturers from a certain region. Seems if you are going to steal "the formula", you had better make sure it is the right formula for high ripple current e-caps
Be not afraid of electrolytics. They may even outlast *you*!
Thank you for all of the input, everyone!
