OK tell me how bad I screwed up
in Propeller 2
I had my eval board working in my car and only had to get 5 analog inputs working. I have dividers on three inputs to lower the 12 volt signals. Two only get up to 1 volt from the O2 sensors so no dividers. I was testing the three 12 volt inputs to determine the values for 0 to 12 volt thru the dividers. It was going ok until I accidentally touched one of the straight in pins with 8.5 volts! Smile, saw a spark. Now no P2. The red error light is on by the usb connector.
Give me the bad news. Did I fry the whole chip?
do you see 5v and 1v8 in any combination?
Plugged into the aux usb there is 1.8 v and 5 on the 5 volt header.
With it plugged into the aux usb and the pc in the pc usb there is no red error light but it still will not find the P2 chip.
Ken will respond shortly.
Would need to pull up the schematic and suggest some other tests from work tomorrow. There might be a way to bypass the fault too... Are you ok doing a bit of soldering?
BTW... Which country is the eval board in?
We'll get you back up and running ASAP. Call Parallax and talk to Christina in sales (press 1). She is checking to see if we have any more boards now.
about this... with the voltage shunts removed you won't find the P2 chip. If your familiar with FT_PROG you could try reading the ftdi chip whilst eval is powered from the aux usb socket. That would determine if that part is working.
Or you could put the 1v8 and 5v headers back on, power the aux usb, then connect pc usb and try detecting the P2. If that works we can get you a little bypass fix worked out that you might be able to apply yourself.
Kind regards, Samuel Lourenço
The pc does see the usb port still.
I found ft_prog and it reads the ftdi chip fine with either connector powering it.
I went back and removed the 5v and the 1.8v jumpers and there is 5 volts and 1.8 at the ldo pins with the usb connector powered and no red light with the jumpers removed.
I guess that looks like the chip is gone, right?
All is not lost yet, and you've proven the Ftdi so that's good!
Actually... with both the 1v8 and 5vldo jumpers on, and powering from usb-aux, you could try measuring all the 3.3v outputs at the edge headers. I'm supposing you'll find one that's not 3.3v!
The pins will be labelled Vxxxx, like V0007 for the first header.
Kgracey@parallax.com
OK on the way, thanks
VonSzarvas-- I found the 3.3 regulator for that pin header was shorted. I removed it and now the 5 v and the 1.8v are ok with the jumpers on and no red error led.
But still no communication with the chip.
@VonSzarvas and @cgracey - let me know if you want his board back for a F/A.
Hi @CRST1
Seems you zapped the board on one of the two most sensitive IO groups!
Glad that Ken could step in with a replacement. Parallax being AWESOME as always!
It would be interesting to determine if the P2 survived other than IO's P24 to P27. Seems a very high chance. If possible, would you consider posting the old one back to Parallax, for the attention of Ken ?
If you do that, I'll share the results of surgery back here!
Apart from testing all the caps and other things in that voltage path, I'd replace the LDO, cut the VIO trace into the P2 chip at VIO2427, and if the short doesn't remain it should be a usable board.
The P2 is really well segmented, and can keep going if some IO groups are damaged... except for the clock group VIO2831 and if further programming is required then VIO5663.
For super stout customer application, maybe P28 to P31 should have isolation or protection added right by the P2, so that a short to those pins cannot blow the clock supply. We'll look at that for the next Eval release; it's a good lesson from this destructive event!
Parallax Inc.
599 Menlo Drive
Rocklin, CA 95765
