Question about FlexGUI/FastSpin _ Cordic Issue _
Reinhard
in Propeller 2
I try to write a cordic example in C with FlexGui (running with wine under Linux)
I want use the _rotxy - Function.
But i get a compiler error : error: unknown identifier _rotxy used in function call
Maybe not implemented yet ?
Then i make a quick and row workaround with own function and inline asm.
The list file and a test with spinsim looks good, i get the expected values.
But how can i use the functions with FastSpin ?
thank's for help
Reinhard
thank's for help
Reinhard
I'll try to get some of those missing propeller2.h functions implemented before the next release.
Eric
It is a very helpful tool.
The communication about structs I find a good solution.
Thank's
Reinhard
void my_rotxy (cartesian_t * input, cartesian_t * output, uint32_t angle) { int32_t x = input->x; int32_t y = input->y; __asm { setq y qrotate x,angle getqx x getqy y }; output->x = x; output->y = y; }function call example is
the inline assembler works very well.
//Example: Multiplication of 2 complex numbers //input: z1 = real1,imag1 // z2 = real2,imag2 //calc: z3 = z1 * z2 //output: real3,imag3 // //testcase: z2 = conj(z1) //expected: z3 is pure real. imag3 = 0. // // //how to compile //wine ../../fastspin/fastspin.exe -I ../../fastspin/include -l -2b --code=cog cplx_mult_c.c #include <propeller2.h> void cplx_mult (int32_t real1, int32_t imag1, int32_t real2, int32_t imag2, int32_t * real3, int32_t * imag3) { int32_t _abs1; int32_t _arg1; int32_t _abs2; int32_t _arg2; int32_t _abs3; int32_t _arg3; int32_t result_lo = 0; int32_t result_hi = 0; __asm { qvector real1,imag1 //z1 to polar getqx _abs1 getqy _arg1 qvector real2,imag2 //z2 to polar getqx _abs2 getqy _arg2 qmul _abs1,_abs2 //multiply the abs getqx result_lo getqy result_hi mov _abs3,result_lo add _arg1,_arg2 //add the phase mov _arg3,_arg1 qrotate _abs3,_arg3 //z3 to cartesian getqx result_lo getqy result_hi }; *real3 = result_lo; *imag3 = result_hi; } void main(void) { int32_t r1 = 100; int32_t i1 = 100; int32_t r2 = 100; int32_t i2 = -100; int32_t r; int32_t i; cplx_mult (r1,i1,r2,i2,&r,&i);//ok cplx_mult (100,100,100,-100,&r,&i);//ok }
