Is this project possible with just one Propeller Board
fishy116fishy116 Posts: 2
edited 2019-11-22 - 16:35:25 in Propeller 1
I am planning on using at the least the Propeller ASC+ https://www.parallax.com/product/32214 to do a project and I want to know if all of this is compatible with the Spin language.
* WIFI module
* LCD Display (maybe this one https://www.adafruit.com/product/1596)
* General I/O data inputs/outputs
* ADC input
* Write to external storage like SD card or other memory module
The main concerns that I have are that the display might use up all the available pins that I'll need for those other functions, and that Spin might not have libraries or code examples of displays and WIFI capabilities. If anyone could confirm that all of these functions are compatible with Spin or point me towards a direction where I could find out myself I'd really appreciate it.
  • jmgjmg Posts: 14,149
    fishy116 wrote: »
    You posted this in Propeller 2, but mention a no-longer-produced Prop1 board.
    That LCD is a 5.0" 40-pin TFT Display - 800x480 with Touchscreen, so your problem with P1, will be RAM, as well as pins. Even at 1 bit per pixel, that display is 48k and P1 is 32k
    What do you need to display ?
    How many do you intend to make ?
  • I’ve posted p1 code for eve2 based display modules such as those that newhaven and matrix orbital sell
    That may help simplify...
    Prop Info and Apps: http://www.rayslogic.com/
  • jmg wrote: »
    fishy116 wrote: »
    I intend to make one of them as a prototype.
    The display only needs to show simple shapes and text as an informational display.
    As I mentioned I'm only seeing if this is possible or if I'll need to interface it with a second micro-controller for additional features.
    I did not know which version that board was as it just says Propeller. Sorry about the forum location, I'll know better next time.
    Thanks for the feedback so far.
  • Since you are here...
    Should mention that P2 would be perfect for that project...
  • ModEdit: Moved to Propeller 1 category.
  • fishy116 wrote: »
    * WIFI module
    * ADC input
    The P1 and spin could certainly handle the WIFI module, general I/O, ADC input, and external storage like SD card or other memory, but the small 32K memory would limit the video to a monochrome or very small color palette unless it could be done in a text/sprites manner.
    As Rayman posted, the P2 would be great for this if you can get one, since it has a much larger 512K of ram and 64 I/O pins. Since you also need a WIFI module you might want to consider using a Propeller 1 module or board and a Raspberry Pi Zero W. The propeller would handle the ADC and digital I/O while the RPi handles the video and WIFI. The cost would very close to that of a P1 or P2 and WIFI module and provides video, wifi, bluetooth, SD, more memory and greater data processing power.
    In science there is no authority. There is only experiment.
    Life is unpredictable. Eat dessert first.
  • The matching driver board looks tempting: https://www.adafruit.com/product/1590
    Lots of RAM, touchscreen interface, backlight driver, needs only 5 pins, and they have example code, though it's in C. If nothing else, that would get your test system going and let you concentrate on the other parts.
  • That looks similar to the ssd1963 that I’ve used with P1 .
    I’ve posted code for that one here.
  • I have a 7" nextion screen connected to my p1 and it all works perfect but the screen is programmed separately and not dependant on the P1
  • I'm using displays that are similar in my project and have looked at those exact modules before. I'm using SSD1963 driven 7" and 3.2" pcbs with the 2x20 pin header you can find on ebay, amazon and other places. Even with the help of the SSD1963 controller, the propeller 1 struggles to drive these displays by itself though.
    As several have stated here before, the 32k limit of the propeller's RAM is going to be the biggest problem. The next problem would be getting the timing just right, as I think it would take some very complex code to drive these displays directly from any micro. I wouldn't even consider trying to drive the dot/clock type display with the p1 unless I had nothing but time to waste. I think it COULD be done with the P2, although I think you'd still bump into memory constraints REAL quick.
    As Rayman recently recommended to me, the FTDI Eve2 might be a much better display choice, depending on what you want to do. It would take care of a LOT of the hard work, allowing the p1 to do what it's good at. They're kinda pricy though.
    https://www.newhavendisplay.com/eve2-tft-modules-c-1_990_992.html
    Depending on the number of I/Os and ADCs you need, you might be able to get away with using one of the controller drivers like this one.
    You may also look at the modules I use since they CAN be driven by the p1 and take care of a lot of the support circuitry. A 5" display module like this is available if you are really going for some REAL basic gui functions.
    https://www.sainsmart.com/collections/all-for-arduino/products/5-tft-lcd-for-arduino-due-mega2560-r3-raspberry-pi
    I (back when I was Average Joe) tried using a P1 connected directly to a controller driven display and quickly determined more memory was necessary. I was able to build simple gui interfaces and other things but they were slow, very simple and somewhat clunky. If it wasn't for the built in P1 font, it would have been nearly IMPOSSIBLE!
    This thread has a LOT of information about the controller driven displays and the p1, although it's a bit congested with debugging... and more of my stupidity than I'd like to admit to :lol:
    https://forums.parallax.com/discussion/137266/propeller-gui-touchscreen-and-full-color-display/p1
    Here was my first direct p1 to ssd1289 controller driven lcd hardware attempt... With one SigmaADC, I had 2 free propeller pins.
    https://forums.parallax.com/discussion/comment/1075047/#Comment_1075047
    As I said, I quickly decided 32k was not enough RAM, especially with almost 2/3 taken by the SD card driver. Over the years I've refined the hardware and am porting LOTS of P1 code over to the P2 and am somewhat documenting the progress in my thread here:
    https://forums.parallax.com/discussion/169021/p2-touchscreen-memory
    The display is going to be the tough one. There's a lot of ways to get a spin compatible 5" display. Without knowing a bit more about the application it's hard for me to say what the best choice would be.
    The WX wifi module is one of my favorite recent purchases and is totally spin compatible :smile:
    Kye's SD driver is great and all spin, and there's also a version of spin FSRW as well.
    Sigma-ADC works pretty good and there are lots of spin drivers for ADCs in the obex.
    I'd say doable. The more info about your app you are able to give, the more help the community will be able to give you.
  • MJBMJB Posts: 1,135
    edited 2019-12-06 - 15:36:05
    I have been using 320x240 QVGA displays via SPI based on ILI9341 like this
    https://www.aliexpress.com/item/32599693865.html?spm=a2g0o.productlist.0.0.2f20b49d1TmrHM&algo_pvid=621d2baf-970f-4aa0-a034-3ca3a6643485&algo_expid=621d2baf-970f-4aa0-a034-3ca3a6643485-8&btsid=0ab1aad2-0941-473a-9357-008201ab874a&ws_ab_test=searchweb0_0,searchweb201602_1,searchweb201603_53
    with Tachyon.
    If you do not need a full grafics buffer you can just draw and write to the display
    which will keep the image for you. Not much RAM needed for this.
  • Capt. QuirkCapt. Quirk Posts: 783
    edited 2019-12-08 - 02:27:09
    cheezus wrote: »
    Is using the unused portion of a larger eeprom (like a 64kb)
    a viable alternative for the P1? or does it need to be located
    in ram?
    The problem is the fonts?
    Bill M.
  • cheezus wrote: »
    in ram?
    Bill M.
    Like I said, it really depends on what you want to do. The Propeller 1 has the ROM font, which is really quite handy and looks pretty nice. If you want other fonts, then they will need to be loaded into RAM. I guess you could read them directly from an external media but this would incur a performance hit. A larger EEPROM could be good for holding assets, although I prefer to keep them on SD cards.
    One of MY biggest problems when building large projects (you may have other issues) is Kye's SD card driver takes about 2/3rds of HubRam. FSRW is a bit smaller but still uses a large percentage of HubRam. Kye's driver is nice because multiple, independent programs, can be chained together to simulate a program larger than 32k. I've used this quite a few times to get around the memory limits, since any project I've run out of memory on already uses an SD card.
    MJB brought up a good point about the QSPI displays. There's also async serial displays that only use 2 pins... Lots of options!
  • Speaking of displays. Has anyone interfaced the com20t2p11ilc from Ortustech? A customer wants this display. It is really nice, good viewing angle, their technology makes it ideal for sunlight and indoor operation.
    But their interface documentation is very limited.
    Reinhardt
  • cheezus wrote: »
    Hmm, for me (compiling with PropTool), it takes up almost exactly 25% of Hub. I also have a read-only version lying about that saves ~2K.
  • Peter JakackiPeter Jakacki Posts: 8,795
    edited 2019-12-10 - 12:29:19
    I checked Tachyon and it uses 4330 bytes for the FAT32 virtual memory filesystem. However it seems the op had joined long enough to do a hit and run.
    Username    fishy116
    Joined    2019-11-23 - 02:15:37
    Visits    1
    Last Active    2019-11-25 - 05:24:19
    Roles    Registered Users
    Posts    2
    P2 --- The LOT --- TAQOZ INTRO & LINKS --- P2 SHORTFORM DATASHEET --- TAQOZ RELOADED - 64kB binary with room to spare
    P1 --- Latest Tachyon with EASYFILE --- Tachyon Forth News Blog --- More
    paypal.png PayPal me
    Brisbane, Australia
