$27 OBO Mecanum Wheel RC Toy
WOW, just found this and sent a $25 offer. Very cheap for a whole mecanum vehicle, you can't even buy the just wheels that cheap. Good toy and hopefully a good chassis to hack. https://www.ebay.com/itm/352817411944
https://www.ebay.com/itm/163895718120
Suction fan burns a lot of current to stick to the wall, FYI.
I'm showing @27.89.
https://www.nytimes.com/2019/09/25/business/universal-postal-union-withdraw.html
@Pub: New ebay trickery afoot. They make it look like $28 until you click on the drop down list of multiple items and the item pictured costs way more. An accessory or completely different item is what costs the teaser price. Shameful!
The wheels may look nicer but the rollers are conical. The first one looks to have properly shaped rollers.
I was wondering why the video did not show the true capabilities of an omnidirectional vehicle. After reading the product description I now know why, the control inputs are not proportional;
Yes, Vex wheels with 3d printed adapters to mount them to the gearmotors.
It is actually 1/4" MDF, since then I have found a good source for Baltic Birch so if I were to do it again, it would be plywood.
Does anyone know of impellers that're functionally equivalent to Mechanum wheels for use in the water? It would be handy to be able to slip sideways against a transverse current without having to rotate the entire craft to compensate.
This is the first video I found that shows how they work. I also do not agree with the wikipedia image that depicts the thrust vectors - notice that all the arrows point in the same direction, as if there were no drag. The foil at the six o'clock position should have the arrow in the opposite direction.
There is one on eBay (for RC models) right now for a mere $380, free shipping!
Aside from that, four paddle wheels with the paddles oriented at a 45 degree angle to the axis of rotation would achieve that. You would want the hull to be a shallow dish shape to so that it could move freely in any direction. Sounds like a fun project...
So am I right to infer that the Voith-Schneider drive requires only two control inputs -- one for velocity and one for direction? Or are two orthogonal inputs required for direction?
Given the mechanical complexity, it'd probably make more sense to buy rather than to build.
Last year in school robotics I built a meccanum bot with the vex v4 system. I had no motor precision, though, and by the time I built the rest of the bot, I was burning servos.
Oh how I wish our school robotics could be open-source!
On the wheel subject, if one were to 3D print these, what materials would be needed for the rollers?
Here are some ideas;
Coat the plastic roller in Plasti-Dip.
Stretch some vinyl tubing over the plastic roller - use a hair dryer to make it more pliable.
Print using a flexible filament - dual print heads would be useful for this.
Coat the plastic rollers in Goop - the glue, not Gweneth Paltrow's garbage.
I am sure there are many more ways too.
