Auto Detect P2ASM for P2D2 and P2EVAL boards
Cluso99
The attached P2asm code automatically detects the P2D2 or P2EVAL boards.
A pull-down resistor is needed on Pin 25 of the P2D2 and not be present on the P2EVAL. There is a ground pad 0.4" from pin 25. I suggest using 10K.
You can change these Pin constants to something other that the values I have chosen.
The program determines whether the pull-dwon exists and sets the xtal and baud appropriately and then outputs a message to the serial port every 1 second, and flashes Pin 0 on the P2D2 (I have a green led on this pin) or flashes the blue led on Pin 56 of the P2EVAL every second.
I have provided duplicate CON calculations for each board and select the appropriate set for further use.
Perhaps someone might like to work out the pasm code to calculate the clock and baud values as variables???
If the prop2 is already operating from RCFAST/RCSLOW clock mode then they do nothing. If the prop2 is in some other clock mode prior then the two step rapid change is of no benefit and may even increase the chances of triggering a lock up because the PLL and crystal both are being issued a shutdown immediately followed by a startup.
There is two known ways to work around the lock-ups with the PLL sourced sysclock selector, either know and use the prior PLL config so as to change clock source selection orderly, or assume that RCFAST hand-over is in effect.
This would look pretty much like the "use known prior mode" method but is internal to the loader. It doesn't require any parameter passing. Here's earlier snippets on the subject - https://forums.parallax.com/discussion/comment/1475472/#Comment_1475472
1: Prior mode handover
2: RCFAST handover
Since you’re the master of the clock section, would you like to fix up the code to do it properly?
I did presume it’s use would be from power up and loaded from Flash or SD. But of course it could be downloaded, or loaded from FAT following some other code.
It should also save the correct values in hub $00010... and some ID too.
I looked for some difference between the boards but I couldn’t see anything that I could see by software so I had to resort to a pull down. I could have used a pull-up similarly too. I have pin sockets on my P2D2s so it was easy to plug in a resistor permanently like I’ve done for SD booting.
So the first choice is which of those two methods to use. Your choice.
Checks hub to see if clkmode is set and if !0 will disable the oscillator
Then sets up the new clkmode, and also saves clkmode and clkfreq to hub $14 & $18
@evanh,
would you mind checking this out please?
extract only... '+-------[ Select desired clock frequency ]------------------------------------+ _CLOCKFREQ = 160_000_000 ' clock frequency _BASEFREQ = 4_000_000 ' common base freq after XDIV '+-------[ Crystal Parameters ]------------------------------------------------+ _XTALFREQ2 = 12_000_000 ' P2D2 crystal frequency _XOSC2 = %01 'OSC ' %00=OFF, %01=OSC, %10=15pF, %11=30pF '+-----------------------------------------------------------------------------+ _XTALFREQV = 20_000_000 ' P2EVAL crystal frequency _XOSCV = %10 '15pF ' %00=OFF, %01=OSC, %10=15pF, %11=30pF '+-----------------------------------------------------------------------------+ ' calculate values (auto)... _XDIV2 = _XTALFREQ2 / _BASEFREQ ' P2D2 crystal divider _XDIVV = _XTALFREQV / _BASEFREQ ' P2EVAL crystal divider _XDIVP = (_CLOCKFREQ > 200_000_000) ? 2 : 1 ' if >200MHz /2 else /1 _XMUL = _CLOCKFREQ / _XDIVP / _BASEFREQ ' clockfreq = crystal / div * mul /divp _XPPPP = ((_XDIVP>>1) + 15) & $F ' 1->15, 2->0, 4->1, 6->2...30->14 _CLKMODE2 = 1<<24 + (_XDIV2-1)<<18 + (_XMUL-1)<<8 + _XPPPP<<4 + _XOSC2<<2 ' %0000_000e_dddddd_mmmmmmmmmm_pppp_cc_00 ' P2D2 setup _CLKMODEV = 1<<24 + (_XDIVV-1)<<18 + (_XMUL-1)<<8 + _XPPPP<<4 + _XOSCV<<2 ' %0000_000e_dddddd_mmmmmmmmmm_pppp_cc_00 ' P2EVAL setup _XSEL = %11 ' %00=rcfast(20+MHz), %01=rcslow(~20KHz), %10=XI(5ms), %11=XI+PLL(10ms) ......._...._.._11 ' XI+PLL '+-----------------------------------------------------------------------------+ DAT org 0 'hubaddr if first loaded into hub $0 entry jmp #begin '00000 skip over hub pcb long 0 '00004 0=P2D2, 1=P2EVAL clkmode_p2d2 long _CLKMODE2 '00008 clockmode for P2D2 clkmode_p2ev long _CLKMODEV '0000C clockmode for P2EVAL baud long _BAUD '00010 -spare- clkmode long 0 '00014 will store clkmode clkfreq long _CLOCKFREQ '00018 will store clkfreq bitper long _BITPER '0001C bit period to load into smartpins '+-----------------------------------------------------------------------------+ '+-------[ check for 10K pull-down on pincfg ]---------------------------------+ begin drvh #pincfg '\ drive pin hi waitx #30*1 '| wait >1us flth #pincfg '| float pin waitx #30*5 '| wait >5us testp #pincfg wc '/ P2D2=nc=pull-dn mov pcb, #0 ' P2D2: preset = 0 mov clkmode, clkmode_p2d2 ' P2D2: preset val if_c mov pcb, #1 ' P2EVAL: set = 1 if_c mov clkmode, clkmode_p2ev ' P2EVAL: set val '+-------[ Set Xtal for P2D2 ]-------------------------------------------------+ rdlong lmm_x, #$14 wz ' if 0 skip pll fixup if_z jmp #.skip andn lmm_x, #_XSEL ' remove enable bit just in case hubset lmm_x ' ... and disable waitx ##20_000_000/30 ' ... ~33ms .skip wrlong clkmode, #$14 ' write to hub $00014 wrlong clkfreq, #$18 ' write to hub $00018 hubset clkmode ' setup oscillator waitx ##20_000_000/100 ' ... ~10ms or clkmode, #_XSEL ' ... add enable bits for XI+PLL hubset clkmode ' ... enable oscillatorThe first 33 ms WAITX probably isn't useful either since you're already treating the PLL as engaged and just needs an update for the desired clock frequency. The reason for having a PLL shutdown pause in the loader code is to fully replicate RCFAST boot conditions if implimenting the RCFAST handover method.
So, if you look at my code, the clkmode will be loaded as zero, so when the code gets copied into cog and run I check for 0 and if so, I skip it.
If however, my code is loaded by some other method and it does not overwrite hub $0 (specifically $14) and it has a non-zero value, I use it to reset the oscillator, then write hub $14 and $18 with the new clkmode and clkfreq and then set the new values into the oscillator.
Even though it's not used, you should fix up the filling of clkfreq with the _CLOCKFREQ value though. Could do similar to clkmode where you've MOV'ed the update into it. My working code has variable XMUL so clkfreq is recomputed even on first init:
I wasn't intending at this stage to allow for changing the clock frequency in this program. Probably that will be in another program.
But I'll add this info into the comments in my program for later use. So thanks for that
.skip wrlong clkmode, #$14 ' write to hub $00014 wrlong clkfreq, #$18 ' write to hub $00018 hubset clkmode ' setup oscillatorBTW when I fixed the (_CLOCKFREQ > 180_000_000) ? 1 : 2 statement I discovered a bug where I was dividing divp instead of multiplying. Here is the fix. I'll post an update later.
All you need is a MOV clkfreq, ##_CLOCKFREQ before the above code.
Are you saying that the loader will load the binary into hub starting at hub $0, then overwrite hub location(s) $14 and or $18 with new values, change the clock, and then load my program into cog $0 and execute it???
That will kill many programs that do not account for the hub $14/$18. That would be a disaster waiting to happen!!! Have I got this right???
EDIT: RCFAST handover method avoids all that by having the loader always reset back to RCFAST before doing the COGINIT.
- With -SINGLE option, loadp2 downloads the prop2 binary as Prop_Hex ROM routine, so is effectively using the RCFAST handover then. The binary is not modified.
- With -PATCH option, loadp2 uses its "mainloader" code to configure the prop2 clock frequency and patches the prop2 binary in loadp2 memory before downloading as 8-bit binary. This downloads faster than -SINGLE.
- Without either option, loadp2 uses its "mainloader" code, programs the prop2 clock frequency, but leaves the binary untouched. This is the original method that's proven unreliable.
Thanks for the explanation
I'm personally in favour of universally adopting RCFAST handover as the only method - removing prior-mode handover as an option. Let the resevered mailboxes be the same as on the prop1.
The three loading methods are -CHIP, -FPGA and -SINGLE. -CHIP and -FPGA use a secondary loader, and are used to load either into the silicon chip or the FPGA. -CHIP and -FPGA will also setup the clock frequency.
-SINGLE does not use a secondary loader, and it does not change the clock frequency.
-PATCH is use to patch locations $14, $18 and $1C with the clock frequency, clock mode and user baud rate. These locations will not be changed if -PATCH is not specified.
Thanks for the enlightenment on the $1C baud location. I was setting baud at $10 and bitper at $1C so I'll fix that.
BTW it's baud not baud rate even tho it sounds better. Something that was ingrained into me in the 70's
* store BAUD in hub $1C
* locals bitper,clkfreq,clkmode,baud --> bitperx,clkfreqx,clkmodex,baudx
First silicon is "A" which is the same for Prop123-A9 / BeMicro-A9, 8 cogs, 64 smart pins
Second silicon is "G"
Here are strings that may also be checked...
first silicon
fc260 14d 72500a0d text_ver byte 13,10,"Prop_Ver ",ver,13,10,0,0
fd014 4d2d3250 _str_vers byte "P2-MONITOR V1.0",$0D,$0A,0
second silicon
fd014 4d2d3250 _str_vers byte "P2-MONITOR V1.3",$0D,$0A,0
Don't forget these are copied from ROM into the top of hub so they can subsequently be overwritten!
Note the Monitor & Serial driver in ROM uses (ie overwrites once invoked) the first 80 bytes from $FC000.
I thought you'd have the that bug sorted in AutoDetect-007.
-SINGLE for RCFAST handover, or
-PATCH for prior-mode handover.
Loadp2's old method is only reliable with the FPGAs, since they don't have the PLL select flaw, so you shouldn't be using that option with the real chips. It will only cause future grief.
