The BS2p24
in BASIC Stamp
I built a plug-in breadboard using a BS2e to control 120 vac 60 Hz solenoids via electronic switches in accordance with specific hours and minutes read from a real-time clock. This controller worked perfectly...then I added a BS2p24 to gather one-wire measurements that were processed and the results sent to the BS2e for controlling the solenoids. What happened was the BS2p24 would stop running its program whenever a solenoid would activate and deactivate.
If you have encountered this problem with the BS2p24 and have a verified solution...I would appreciate knowing what needs to be done to prevent the problem. I suspect EMI pulses are the culprit but have not verified the mechanism.
Sincerely,
Discovery
Sincerely,
Discovery
Sincerely,
Discovery
The observation that the problem was solved was an error...the BS2p24 program actually stopped when the solenoids activated. The solenoids fully engage in the first quarter cycle drawing about 10 amps on the 120 vac line which produces a powerful EMI pulse. What is interesting, is that the BS2e micro controller is not affected by the pulse as the two controllers are plugged into a wiring board. So, I began some experiments by adding 0.01 microfarad ceramic disk capacitors to the Vcc/Vee pins on both controllers. This had no affect. I added a 1.0 microfarad Mylar capacitor and 47 microfarad Tantalum capacitor from the 9 volt regulator rail to the ground rail with no change. I moved the BS2p24 to a separate plug-in wiring board using shielded coax 12 vdc power cables with no affect. I then machined a block of aluminum in which the BS2p24 plug-in board was placed. Coax fire-wall connectors were installed for the 12 vdc power and the One-wire signal interface. This grounded the entire aluminum block to the power supply and all sensors. Data wires were connected between the two controllers and this configuration worked properly. I did not expect the BS2p24 to be so sensitive to EMI.
So AwesomeCronk, you were in the right track.
Sincerely,
Discovery
My configuration uses zero crossing triac opto-isolated electronic switches to drive the coils of the solenoids. Zero crossing detection is not the problem...the EMI pulse from the solenoid activation is the problem.
Sincerely,
Discovery
Sincerely,
Discovery
Sincerely,
Discovery
Discovery
Sincerely,
Discovery
do you have some pictures you could share?
The first picture shows the machined aluminum enclosure with the coax cables attached to feed-thru connectors.
An output cable connects the aluminum enclosure circuits to the electronic switches shown in the second picture. The white cables interface with the solenoids. The interface cable does not require shielding.
Sincerely,
Discovery
Discovery
