Load P2 via wifi? — Parallax Forums
Load P2 via wifi?
I just got a WX activity board and was thinking about testing out the load over wifi tools.
That made me wonder if we can load the P2 ES board over wifi using a parallax wifi module...
Does this capability already exist? If not, is it easily added?
  • Rayman wrote: »
    It doesn't currently exist but it could be added. Actually, you might be able to do it by just making a telnet connection to the WX module and blasting data at the P2. You'd have to manually reset the P2 first though. Is there a defined pin for reset that could be wired to DTR?
  • FYI, the only reason the WX wifi module knows how to load the P1 is that the P1 loader protocol is very time sensitive and it works badly over a network connection. This probably isn't true of the P2 loader protocol so it is likely that all that is needed is a way to reset the P2. That would be simple to implement. Toggling DTR to reset the P1 already exists but I'm not sure it is available as a separate operation. It's usually used in conjunction with initiating a P1 load operation. All that would be needed is to add a separate command to just do the DTR reset by itself.
  • RaymanRayman Posts: 16,213
    Maybe the new ES board should have a WX module header on it?
  • Rayman wrote: »
    That would be nice except that it sounds like it's already designed and in production.
  • ElectrodudeElectrodude Posts: 1,686
    edited 2019-08-23 21:16
    Solder a header into the DTR and RESn holes near the P56-P63 header and make a wireless programming accessory board that plugs into both the DTR/RESn and the P56-P63 header.
