Arduino Phone for everyone..
                    With this project I hope to inspire Propeller Users to use their propeller chips in extraordinary ways...
the Arduino Phone tutuorial can be found here:
https://learn.adafruit.com/arduin-o-phone-arduino-powered-diy-cellphone
Videos are in Google Drive; need to sign into your google account to see videos...
Setup Video...
https://drive.google.com/file/d/14aXtKm3bm8QCTC-PcwJiBOXlvcHOtD9j/view?usp=sharing
Assembled Video... (did not realized it was connected to the cell tower network... lol... )
https://drive.google.com/file/d/18app1M2mvfWtT5454WbMyqF2oSP_BR5l/view?usp=sharing
Phone call Video..
https://drive.google.com/file/d/19UGFEW84zQUdP5D_xtdnbcjrtxbx0TnV/view?usp=sharing
Have a great time in your Microcontroller Adventure!!!
Cheers...
Setup Video...
Phone call Video..
Cheers...
/* does: * can make calls on the speaker & mic todo: * status notification updates in loop() * dim screen when no touches in 1 minute * receive calls * receive texts * candy crush */ #include <SPI.h> #include <Wire.h> // this is needed even tho we aren't using it #include "Adafruit_GFX.h" #include "Adafruit_ILI9341.h" #include <Adafruit_STMPE610.h> #include <SoftwareSerial.h> #include "Adafruit_FONA.h" #define FONA_RX 2 #define FONA_TX 3 #define FONA_RST 4 SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX); Adafruit_FONA fona = Adafruit_FONA(FONA_RST); // For the Adafruit TFT shield, these are the default. #define TFT_DC 9 #define TFT_CS 10 // Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC); // The STMPE610 uses hardware SPI on the shield, and #8 #define STMPE_CS 8 Adafruit_STMPE610 ts = Adafruit_STMPE610(STMPE_CS); // This is calibration data for the raw touch data to the screen coordinates #define TS_MINX 150 #define TS_MINY 130 #define TS_MAXX 3800 #define TS_MAXY 4000 /******************* UI details */ #define BUTTON_X 40 #define BUTTON_Y 100 #define BUTTON_W 60 #define BUTTON_H 30 #define BUTTON_SPACING_X 20 #define BUTTON_SPACING_Y 20 #define BUTTON_TEXTSIZE 2 // text box where numbers go #define TEXT_X 10 #define TEXT_Y 10 #define TEXT_W 220 #define TEXT_H 50 #define TEXT_TSIZE 3 #define TEXT_TCOLOR ILI9341_MAGENTA // the data (phone #) we store in the textfield #define TEXT_LEN 12 char textfield[TEXT_LEN+1] = ""; uint8_t textfield_i=0; // We have a status line for like, is FONA working #define STATUS_X 10 #define STATUS_Y 65 /* create 15 buttons, in classic candybar phone style */ char buttonlabels[15][5] = {"Send", "Clr", "End", "1", "2", "3", "4", "5", "6", "7", "8", "9", "*", "0", "#" }; uint16_t buttoncolors[15] = {ILI9341_DARKGREEN, ILI9341_DARKGREY, ILI9341_RED, ILI9341_BLUE, ILI9341_BLUE, ILI9341_BLUE, ILI9341_BLUE, ILI9341_BLUE, ILI9341_BLUE, ILI9341_BLUE, ILI9341_BLUE, ILI9341_BLUE, ILI9341_ORANGE, ILI9341_BLUE, ILI9341_ORANGE}; Adafruit_GFX_Button buttons[15]; // Print something in the mini status bar with either flashstring void status(const __FlashStringHelper *msg) { tft.fillRect(STATUS_X, STATUS_Y, 240, 8, ILI9341_BLACK); tft.setCursor(STATUS_X, STATUS_Y); tft.setTextColor(ILI9341_WHITE); tft.setTextSize(1); tft.print(msg); } // or charstring void status(char *msg) { tft.fillRect(STATUS_X, STATUS_Y, 240, 8, ILI9341_BLACK); tft.setCursor(STATUS_X, STATUS_Y); tft.setTextColor(ILI9341_WHITE); tft.setTextSize(1); tft.print(msg); } void setup() { Serial.begin(9600); Serial.println("Arduin-o-Phone!"); // clear the screen tft.begin(); tft.fillScreen(ILI9341_BLACK); // eep touchscreen not found? if (!ts.begin()) { Serial.println("Couldn't start touchscreen controller"); while (1); } Serial.println("Touchscreen started"); // create buttons for (uint8_t row=0; row<5; row++) { for (uint8_t col=0; col<3; col++) { buttons[col + row*3].initButton(&tft, BUTTON_X+col*(BUTTON_W+BUTTON_SPACING_X), BUTTON_Y+row*(BUTTON_H+BUTTON_SPACING_Y), // x, y, w, h, outline, fill, text BUTTON_W, BUTTON_H, ILI9341_WHITE, buttoncolors[col+row*3], ILI9341_WHITE, buttonlabels[col + row*3], BUTTON_TEXTSIZE); buttons[col + row*3].drawButton(); } } // create 'text field' tft.drawRect(TEXT_X, TEXT_Y, TEXT_W, TEXT_H, ILI9341_WHITE); status(F("Checking for FONA...")); // Check FONA is there fonaSS.begin(4800); // if you're using software serial // See if the FONA is responding if (! fona.begin(fonaSS)) { // can also try fona.begin(Serial1) status(F("Couldn't find FONA :(")); while (1); } status(F("FONA is OK!")); // Check we connect to the network while (fona.getNetworkStatus() != 1) { status(F("Looking for service...")); delay(100); } status(F("Connected to network!")); // set to external mic & headphone or headset audio fona.setAudio(FONA_HEADSETAUDIO); //fona.setAudio(FONA_EXTAUDIO); } void loop(void) { TS_Point p; if (ts.bufferSize()) { p = ts.getPoint(); } else { // this is our way of tracking touch 'release'! p.x = p.y = p.z = -1; } // Scale from ~0->4000 to tft.width using the calibration #'s if (p.z != -1) { p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width()); p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height()); Serial.print("("); Serial.print(p.x); Serial.print(", "); Serial.print(p.y); Serial.print(", "); Serial.print(p.z); Serial.println(") "); } // go thru all the buttons, checking if they were pressed for (uint8_t b=0; b<15; b++) { if (buttons[b].contains(p.x, p.y)) { //Serial.print("Pressing: "); Serial.println(b); buttons[b].press(true); // tell the button it is pressed } else { buttons[b].press(false); // tell the button it is NOT pressed } } // now we can ask the buttons if their state has changed for (uint8_t b=0; b<15; b++) { if (buttons[b].justReleased()) { // Serial.print("Released: "); Serial.println(b); buttons[b].drawButton(); // draw normal } if (buttons[b].justPressed()) { buttons[b].drawButton(true); // draw invert! // if a numberpad button, append the relevant # to the textfield if (b >= 3) { if (textfield_i < TEXT_LEN) { textfield[textfield_i] = buttonlabels[b][0]; textfield_i++; textfield[textfield_i] = 0; // zero terminate fona.playDTMF(buttonlabels[b][0]); } } // clr button! delete char if (b == 1) { textfield[textfield_i] = 0; if (textfield > 0) { textfield_i--; textfield[textfield_i] = ' '; } } // update the current text field Serial.println(textfield); tft.setCursor(TEXT_X + 2, TEXT_Y+10); tft.setTextColor(TEXT_TCOLOR, ILI9341_BLACK); tft.setTextSize(TEXT_TSIZE); tft.print(textfield); // its always OK to just hang up if (b == 2) { status(F("Hanging up")); fona.hangUp(); } // we dont really check that the text field makes sense // just try to call if (b == 0) { status(F("Calling")); Serial.print("Calling "); Serial.print(textfield); fona.callPhone(textfield); } delay(100); // UI debouncing } } }Cheers...
I made a security system out of cell phone tech, because if the house power goes out, only cell phone tech will be active with battery backup...
cheers...
Sure, there are many apps for this already. An old Android phone can be put to good use, thanks to all the integrated features.
Anyone can create an app, in minutes with RFO BASIC aka: BASIC! (with the exclamation). This is an interpreter that actually runs on the device.
Makes a great front end for a microcontroller.
