Appcon RF1276 Point to Point P2P Failure over time
kg1
in Propeller 1
Configuration of RF1276:
Parallax Arlo with RF1276 added:
Controller using Propeller:
Output: Arlo
Output: controller
Code for Arlo:
Perhaps there is something more I need to do with the fdserial library?
Comments would be much appreciated.
Many thanks,
Kevin.
Output: Arlo
Output: controller
Code for Arlo:
mobile.c
Demonstrates using full duplex serial communication to exchange information.
https://www.appconwireless.com/showpro.php?id=94
http://learn.parallax.com/tutorials/language/propeller-c/propeller-c-simple-protocols/full-duplex-serial
https://github.com/parallaxinc/Simple-Libraries/blob/master/Learn/Examples/Protocols/XBee%20UART%20Command%20Mode%20Example.c
#include "simpletools.h"
#include "fdserial.h"
#include "compass3d.h"
void compass(void *par);
fdserial *robot;
fdserial *term;
unsigned int stack[44 + 128];
static volatile char dataIn[11];
int main()
robot = fdserial_open(9, 8, 0, 9600); // fdserial *fdserial_open(int rxpin, int txpin, int mode, int baudrate)
pause(1000);
term = fdserial_open(31, 30, 0, 115200);
pause(1000);
fdserial_rxFlush(robot);
cogstart(compass, NULL, stack, sizeof(stack));
int n = 0;
char c;
while(1)
for (int i = 0; i < 11; i++)
dataIn[i] = '\0';
n = 0;
c = fdserial_rxChar(robot);
if(c != -1)
while (n < 10)
dataIn[n] = c;
n++;
if (c == -1 || c == '\n')
break;
dataIn[10] = '\0';
dprint(term, "J%s\n", dataIn);
pause(1000);
else
// dprint(term, "0XAF 0XAF 0X00 0X00 0XAF 0X80 0X20 0X02 00 00 CS 0X0D 0X0A");
int x, y, z; // Declare x, y, & z axis variables
i2c *bus = i2c_newbus(3, 2, 0); // New I2C bus SCL=P3, SDA=P2
compass_init(bus); // Initialize compass on bus.
while(1) // Repeat indefinitely
compass_read(bus, &x, &y, &z); // Compass vals -> variables
float fy = (float) y; // Ints to floats
float fx = (float) x;
float heading = atan2(fy, fx) * 180.0/PI; // Calculate heading with floats
if(heading < 0.0) // Convert -180...+180 to 0...360
heading = (360.0 + heading);
// fdserial_txFlush(robot);
dprint(robot, "%.2f\n", heading);
pause(1000); // Display heading
dprint(term, "%.2f\n", heading);
Code for Controller:
controller.c
#include "adcDCpropab.h"
void joystick(void *par);
fdserial *robot;
fdserial *term;
int main()
pause(1000);
pause(1000);
cogstart(joystick, robot, stack, sizeof(stack));
int n = 0;
char c;
while(1)
dataIn[i] = '\0';
n = 0;
if(c != -1)
while (n < 10)
dataIn[n] = c;
n++;
break;
dataIn[10] = '\0';
dprint(term, "C%s\n", dataIn);
pause(1000);
// pause(1000); // Wait 1 s for Terminal app
adc_init(21, 20, 19, 18); // CS=21, SCL=20, DO=19, DI=18
float lrV, udV; // Voltage variables
while(1) // Loop repeats indefinitely
udV = adc_volts(2); // Check A/D 2
lrV = adc_volts(3); // Check A/D 3
//pause(1000); // Wait 1/10 s
dprint(robot, "%.2f %.2f\n", udV, lrV); // Display voltage
dprint(term, "%.2f %.2f\n", udV, lrV); // Display voltage
// dprint(robot, "%.2f\n", lrV); // Display voltage
// pause(1000); // Wait 1/10 s
At first I had only one or two lines of output but by using dprint(robot, "%.2f %.2f\n", udV, lrV); and dprint(term, "%.2f %.2f\n", udV, lrV); as above the output continues for a short period but finally transmission stops at both ends.Perhaps there is something more I need to do with the fdserial library?
Many thanks,
Kevin.
RF_Factor 1 byte 7=128, 8=256, 9=512, 10=1024, 11=2048, 12=4096
RF_BW: Lora bandwidth. Larger value means lower sensitivity. Recommended value: 125K.
RF_BW 1 byte 6=62.5k, 7=125k, 8=250k, 9=500k
I still do not know what settings are optimum? However the flow of data is much better.
The syncing at power-up could be better. It comes right by itself but I probably need to eliminate data that is not complete. Also at times the data from one "channel" seems to appear in the other "channel". This can also correct itself over time. Where should fdserial_rxFlush and fdserial_txFlush be used?
Kevin.
If the first character is not a "C" or a "J" then the transaction is discarded.
If the length of a joystick transaction is not >= 10 it is discarded.
The compass transactions are not working correctly in terms of correct direction.
/* mobile.c Demonstrates using full duplex serial communication to exchange information. https://www.appconwireless.com/showpro.php?id=94 http://learn.parallax.com/tutorials/language/propeller-c/propeller-c-simple-protocols/full-duplex-serial https://github.com/parallaxinc/Simple-Libraries/blob/master/Learn/Examples/Protocols/XBee%20UART%20Command%20Mode%20Example.c */ #include "simpletools.h" #include "fdserial.h" #include "compass3d.h" void compass(void *par); fdserial *robot; fdserial *term; unsigned int stack[44 + 128]; static volatile char dataIn[13]; int main() { robot = fdserial_open(9, 8, 0, 9600); // fdserial *fdserial_open(int rxpin, int txpin, int mode, int baudrate) pause(1000); term = fdserial_open(31, 30, 0, 115200); pause(1000); // fdserial_rxFlush(robot); cogstart(compass, NULL, stack, sizeof(stack)); int n = 0; char c; fdserial_rxFlush(robot); while(1) { for (int i = 0; i < 13; i++) { dataIn[i] = '\0'; } n = 0; c = fdserial_rxChar(robot); if(c != -1 && (c == 'J')) { while (n < 12) { dataIn[n] = c; n++; c = fdserial_rxChar(robot); if (c == -1 || c == '\r') break; } if (c == -1) { fdserial_rxFlush(robot); break; } if (c == '\r') { dataIn[n] = '\0'; } dataIn[12] = '\0'; if(strlen(dataIn) >= 10) { dprint(term, "%s\n", dataIn); pause(1000); } // dprint(term, "%d\n", strlen(dataIn)); } else { // dprint(term, "0XAF 0XAF 0X00 0X00 0XAF 0X80 0X20 0X02 00 00 CS 0X0D 0X0A"); fdserial_rxFlush(robot); } } } void compass(void *par) { int x, y, z; // Declare x, y, & z axis variables i2c *bus = i2c_newbus(3, 2, 0); // New I2C bus SCL=P3, SDA=P2 compass_init(bus); // Initialize compass on bus. fdserial_txFlush(robot); while(1) // Repeat indefinitely { compass_read(bus, &x, &y, &z); // Compass vals -> variables float fy = (float) y; // Ints to floats float fx = (float) x; float heading = atan2(fy, fx) * 180.0/PI; // Calculate heading with floats if(heading < 0.0) // Convert -180...+180 to 0...360 heading = (360.0 + heading); dprint(robot, "C%.2f\r", heading); pause(1000); // Display heading // dprint(term, "%.2f\n", heading); // pause(1000); // Display heading } }/* controller.c Demonstrates using full duplex serial communication to exchange information. https://www.appconwireless.com/showpro.php?id=94 http://learn.parallax.com/tutorials/language/propeller-c/propeller-c-simple-protocols/full-duplex-serial https://github.com/parallaxinc/Simple-Libraries/blob/master/Learn/Examples/Protocols/XBee%20UART%20Command%20Mode%20Example.c */ #include "simpletools.h" #include "fdserial.h" #include "adcDCpropab.h" void joystick(void *par); fdserial *robot; fdserial *term; unsigned int stack[44 + 128]; static volatile char dataIn[13]; int main() { robot = fdserial_open(9, 8, 0, 9600); // fdserial *fdserial_open(int rxpin, int txpin, int mode, int baudrate) pause(1000); term = fdserial_open(31, 30, 0, 115200); pause(1000); cogstart(joystick, robot, stack, sizeof(stack)); int n = 0; char c; fdserial_rxFlush(robot); while(1) { for (int i = 0; i < 13; i++) { dataIn[i] = '\0'; } n = 0; c = fdserial_rxChar(robot); if(c != -1 && (c == 'C')) { while (n < 12) { dataIn[n] = c; n++; c = fdserial_rxChar(robot); if (c == -1 || c == '\r') break; } if (c == -1) { fdserial_rxFlush(robot); break; } dataIn[12] = '\0'; dprint(term, "%s\n", dataIn); pause(1000); } else { fdserial_rxFlush(robot); } } } void joystick(void *par) { // pause(1000); // Wait 1 s for Terminal app adc_init(21, 20, 19, 18); // CS=21, SCL=20, DO=19, DI=18 float lrV, udV; // Voltage variables fdserial_txFlush(robot); while(1) // Loop repeats indefinitely { udV = adc_volts(2); // Check A/D 2 lrV = adc_volts(3); // Check A/D 3 //pause(1000); // Wait 1/10 s dprint(robot, "J%.2f %.2f\r", udV, lrV); // Display voltage pause(1000); // Wait 1/10 s // dprint(term, "%.2f %.2f\n", udV, lrV); // Display voltage // pause(1000); // Wait 1/10 s // dprint(robot, "%.2f\n", lrV); // Display voltage // pause(1000); // Wait 1/10 s } }Any suggestions please?
