Raspberry Pi 4
 Keith Young
Keith Young
                    New Raspberry Pi 4 is out.
USB 3.0 and Ethernet that isn't excruciatingly slow.
More details:
https://www.raspberrypi.org/blog/raspberry-pi-4-on-sale-now-from-35/
More details:
Mine is on its way!
Dave
Here we are on the cusp of great things only 7 years later....
I like this comment
"The Raspberry Pi website migrated to Pi4 servers on Friday night. https://blog.mythic-beasts.com/2019/06/22/raspberry-pi-on-raspberry-pi/
Eat your own dogfood!"
Product Page:
https://buyzero.de/products/raspberry-pi-4-model-b?variant=28034030927974
Direct link to PDF write-up
https://cdn.shopify.com/s/files/1/1560/1473/files/Inside_Raspberry_Pi_4.pdf?2142
I believe there is a version of a Propeller IDE that runs on a Pi and if so, I would like to update my aged briefcase computer to a Pi4 from the ION A603 mini PC running Win98.
I also see this (my emphasis added)
"The GPIO pinout is exactly the same, and backwards compatible, so it’ll still work with the enormous collection of HATs that have been designed for Pis over the years. But that’s not to say there are no upgrades here at all — the engineers have been able to squeeze in a whole lot more I2C, UART and SPI peripherals onto the various pins, about 6 of each now, adding enormous potential to talk to more devices over these protocols. If you’ve ever run into trouble during a project because you wanted, for example, to include more than one device that uses UART, you’re now good for up to six of them."
another review claims
" and with fixed support for clock stretching over I2C interfaces."
and another page says
"...up to 6 × I2C, up to 6 × UART (muxed with I2C), up to 6 × SPI (only five exposed on Raspberry Pi 4B)..."
All that improved IO, will make this more appealing to talk to a P2
Maybe the SPI and UARTs can go faster too ?
what just 6 UARTS? Just 6 I2C?
Even the P1 can do better with up to 16 of each, double that for the P2!
Enjoy!
Well, yes, if someone needs a lot of ports, I'd expect designers to want to join the two.
Still on the lookout for if there are any speed gains on those extra ports, but that may take a while to shake out.
And this is sponsored by the inhabitants of the totally boring planet of Tatooine.
I'm not sure they had much choice ?
It does break physical compatibility and thus needs new cases and cables, but so do the dual micro HDMI outs and to some degree the rearranging of the USB and ethernet ports.
