Servos wrongly connected
in BASIC Stamp
Hi,
I am resuming the programming of my arduino after years using the parallax manuals, but I am stuck in making the servos work.
I have a Basic Stamo Homework Board USB Rev A powered by a UC1.3-6(6V 1.3 AH/20HR) battery.
I can't remember how the servos should be connected to the stamp. I connected them as detailed in the manual (brown cable to Vss, red cable to Vin, orange cable to the pins) and when I power the board there are no lights twinkling and there's a very low whisle.
I hope anyone can help me with the way the servos should be connected.
Thank you all.
Thank you all.
Your battery puts out over 7V when it's fully charged. That's on the edge of what a servo motor will tolerate. They're much "happier" at 4.5-5V. What happens when you run the Homework Board with 3 or 4 fresh alkaline batteries in series?
Thanks for your feedback.
I wasn't able to download any program to the Stamp, the software shows an error that says that there is no Stamp. I am using version 2.5.4 of the Basic Stamp editor.
I haven't tried with alkaline batteries yet, but I think this is not a battery issue. I found my boe bot some days ago with both servos connected and the last program I downloaded to the Stamp (which I programmed some years ago) and everything was working fine. Then I disconnected everything to study everything from scratch but I couldn't make it with the servos.
Just noticed the battery is 6V, that might not be enough. Not sure.
I think the battery is ok because I have programmed the Stamp to control LEDs and provide feedback using the Debug tag and I had no issued with that, the only issue is that I don't remember how to connect the servos.
I connected the servo's red cable to Vin and brown to Vss and it measured 3 Volts
Where is that voltage coming from, (picture needed). Servos normally need 5 volts to operate.
The (+)Vin pin
Disconnecting the servos it reads 4.6V
