Rigid lift mechanism
I need to lift something 10” travel. For a simple illustration think of a coffee table that becomes a dining room table. The base can be up to 20”x20” and 16” tall. The weight is a few hundred TBD. I was thinking to use my typical Prop based main boards and brushless motors that I apply to various motion needs. In this case it’s a challenge.
I’ve built CNCs with linear rails and carriages. When carriages are spread out and you can have 2 per slide you can get a very rigid system. In this case I can fit 2 carriages back to back barely, not spread out at all With 4 rails vertically oriented in the base, at full height I’m not confident this will be super rigid.
I have used ball screws and nuts. In this case I have some ideas for 4- 3/4” ball screws in each corner doing the lifting. But again due to only having less than 16” height in a base to mount it all, I question if it will be stable. Meaning I don’t want to be able to push on this thing and have it move back and forth 1/4”.
I looked at various linear actuators and even if using 4, one in each corner I question the stability when fully extended. Also if using 4 separate linear motors will they be fairly synced.
What other options exists for a very robust lift that would not allow any bending or movement if pushed on? Meaning a tank.
papacad.com/wp-content/uploads/2017/07/Screw-scissor-table-CAD-project-2.jpg
My main concerns are about each pivoting joint being able to introduce some degrees of freedom, due to the small (and necessary) mounting gaps, which can admit unacceptable oscillations of the whole assembly.
From it, can I understand that you agree to tolerate the lateral movement that would happen, during the up/down lifting process?
And about hinges, are you thinking in using some kind of zig-zag, double pivot-axes piano hinges, up to the limit of your 20" space?
https://www.firgelliauto.com/collections/linear-actuators
https://www.firgelliauto.com/collections/linear-actuators/products/feedback-rod-actuator
As for synchronizing, some of these have a built-in feedback pot, and IIRC some others operate like a servo, they travel to a specified position and stop.
"linearmotiontips" AND "ball screw"
Hope they can help a bit
Henrique
https://skfmotiontechnologies.com/en/se/products/telescopic-pillars/tlt
Big a$$ pneumatic cylinder(s)?
Have pressure regulated so that the air pressure acts as a counter-balance and use a small motor to drive up/down.
Just to offer something different
