Controlling CAN terminator with Propeller pin.
in Propeller 1
I'd like to be able to switch the terminator resistor on and off with a propeller CAN node programmatically instead of using using a physical jumper. I thought of using a tri-state buffer, but the bus voltage goes over the usual 5v allowed. Most of the transistor examples are switching voltage a don't seem valid for the changing voltages of a CAN bus. A physical relay also isn't preferred. There is a way, I just have found the right search terms...
As above, if you want the full transient tolerance of CAN, some isolation is needed.
Phil quotes a 4A SSR, but you might be ok with smaller/cheaper ones. egg CPC1006N, VO1400AEFTR , CPC1002N, TLP241A(TP1,F etc
