P2 Serial Driver — Parallax Forums
P2 Serial Driver
Cluso99Cluso99 Posts: 18,071
edited 2016-06-28 08:18 in Propeller 2
Here is a Serial Driver you can use with P2 code.
There are 3 simple calls...
CALL #_SERIALINIT
CALL #_SEND
CALL #_RECV
The serial driver may reside in cog or hub (hubexec) ram.
  • I was trying your code and got this.
    Martin
    805 x 792 - 50K
  • evanhevanh Posts: 17,107
    Pilot,
    That's really old code. Even with those cases fixed it may not do as intended. That said, to make it assemble, replace each "setb dira/b...." with a "dirh ..."
    There is sample code for the ES chip posted that uses the ROM code. You will need to check the sample code threads for the ES silicon.
    Note any code posted prior to mid/late 2018 is likely to be suspect due to many changes before the P2 design was frozen.
  • @Cluso99
