Demo: Sine Generator with CORDIC Algo in single cog
Hi,
I found this CORDIC Algo years ago in webspace,
saddly I do not remember the origin
// Cordic in 32 bit signed fixed point math
// generate approx. 200 Hz Sine and Cosine (in parallel !)
// Sine signal out on P0 via RC Lowpass
// signal is a little bit strange in negative wave
// have now not found the reason
// main loop can be optimized
// propeller-elf-gcc -mcog -Os -o Cordic_sin.elf main.c
// need 808 Byte CogRam
#include <propeller.h>
#define cordic_1K 0x26DD3B6A
#define half_pi 0x6487ED51
#define CORDIC_NTAB 32
#define P0 1<<0
#define CRTMODE (1<<28) + (1<<27) + 0 // DUTY SINGLE ENDED
int cordic_ctab [] = {0x3243F6A8, 0x1DAC6705, 0x0FADBAFC, 0x07F56EA6,
0x03FEAB76, 0x01FFD55B, 0x00FFFAAA, 0x007FFF55,
0x003FFFEA, 0x001FFFFD, 0x000FFFFF, 0x0007FFFF,
0x0003FFFF, 0x0001FFFF, 0x0000FFFF, 0x00007FFF,
0x00003FFF, 0x00001FFF, 0x00000FFF, 0x000007FF,
0x000003FF, 0x000001FF, 0x000000FF, 0x0000007F,
0x0000003F, 0x0000001F, 0x0000000F, 0x00000008,
0x00000004, 0x00000002, 0x00000001, 0x00000000, };
// it is amazing, this shifts and adds produce a sine function
void cordic(int theta, int *s, int *c, int n)
int k, d, tx, ty, tz;
int x=cordic_1K,y=0,z=theta;
for (k=0; k<n; ++k)
d = z>>31;
tx = x - (((y>>k) ^ d) - d);
ty = y + (((x>>k) ^ d) - d);
tz = z - ((cordic_ctab[k] ^ d) - d);
x = tx; y = ty; z = tz;
*c = x; // cosine
*s = y; // sine
void main()
int j ,k;
int s,c;
int i;
DIRA |= P0;
CTRA = CRTMODE;
LOOP:
j=0;
// 0 .. PI/2 in 50 steps
for(i=0;i<50;i++)
cordic(j, &s, &c, 32);
FRQA = s+1; // cordic result = 0xFFFFFFFF at angle = 0 ?? simple workaround
j += 0x0202b7f2; // PI/2 = 0x6487ED51 | : 50 = 0x0202B7F2
k=j;
j=0;
// PI/2 ... PI in 50 steps
for (i=0;i<50;i++)
cordic(k-j, &s, &c, 32);
FRQA = s+1;
j += 0x0202b7f2;
j=0;
// PI ... 3PI/2 in 50 steps
for (i=0;i<50;i++)
FRQA = s+1;
j += 0x0202b7f2;
k=j;
j=0;
// 3PI/2 ... 2PI in 50 steps
for (i=0;i<50;i++)
FRQA = s+1;
j += 0x0202b7f2;
goto LOOP;
a long time has passed since my last post. I am retired now and have time to polish up my old things.
The Cordic Algo now generates a clean sine / cosine.
Digital signal processing with the P1 and C I still find very interesting.
Enclosed also an application for the physical modeling of musical instruments. This is another approach to creating synthetic sounds in addition to the FM modulation, which have already been implemented in SPIN and the subtractive synthesis as used in the Moog. It simulates a vibrating (guitar) string. The application is for that
Propeller demo board designed.
Have fun, Reinhard.
Commented in the source code.
In the folder 'morecogs' is a first attempt with several parallel cogs, all at the same
Work output. This should correspond to a summer in analog technology. However, this experiment is not yet fully operational.
The goal is another kind of synthesizer.
unzip the attachment in any folder
from LINUX - terminal compile g++ -Wall -o zupf zupf.cpp
run ./zupf_examples_2.sh
(asm I still want to learn)
