To ORGH or not to ORGH? - Page 2 — Parallax Forums
24
  • ersmithersmith Posts: 6,234
    edited 2019-04-09 11:28
    This is a bug in the program code, I think. The variable x is declared as:
    x     res 1
    which does not initialize it, just reserves some space for it (in COG memory... "res" does nothing to HUB memory!). It'll have as an initial value whatever happens to be in HUB memory after the label; in this case it'll be the first instruction of the PropCam_Acq function.
    But in the actual code x appears to be used without being explicitly set, so that initial value will determine the behavior of the program. The first use of x I see is in this loop:
    doVga
                    rdfast	#0,##$1000-$400		'load .bmp palette into lut
    				rep	@.end,#$100
    				rflong	y
    				shl	y,#8
    				wrlut	y,x
    				add	x,#1
    .end
    x is used as the index into LUT for writing, but since it is not set first the results will depend on the contents of HUB memory.
    This explains why everything works if the first instruction after PropCam_Acq is "nop"; in that case x happens to be initialized to the bit pattern of the nop instruction, which is all 0. It also works if you change the "x res 1" to "x long 0", for a similar reason (now x is initialized to 0), or if there's an "orgh" before PropCam_Acq (orgh pads with 0). Another fix would be to insert "mov x, #0" before the rep loop.
  • cgraceycgracey Posts: 14,289
    edited 2019-04-09 12:14
    I think ORGH needs to bump the adress to at least $400 to get around these ambiguities.
    I'm changing PNut.exe to separate the ORGH address from the actual object code address.
    IMHO I don’t think ORGH should prevent values below $400 as we may well want to put buffers, variables and tables there.
  • cgracey wrote: »
    This particular example didn't have anyting to do with ORGH, except accidentally -- it was just use of an uninitialized variable.
    What exactly do you mean by that, Chip? Do you mean that labels will now have 3 values, their default value, notional hub value as set by ORGH, and actual location in HUB memory? This seems like it could get very confusing. I think one of the things people didn't like in P1 was that "@label" had different meanings in Spin and PASM; in Spin it gave you the actual HUB location, but in PASM it just gave you an offset of sorts. It would be nice to fix that in P2.
  • RaymanRayman Posts: 15,951
    edited 2019-04-09 12:41
    What does
    ORGH 0
    do exactly?
    I think it pushes to at least $400.
    I think the way it works now (but could be wrong) is that
    ORGH X
    tries to start code at X in HUB memory with X being made to be at least $400.
    This seems to be working just fine for me...
    edited 2019-04-09 12:48
    BTW: "RES" is nothing but trouble. It's too easy to get caught putting variables after a RES and messing up your code.
    And here, we see how it can really mess you up if you don't realize it's not initiated...
    I'm trying to think if RES serves any use that justifies itself..
    edited 2019-04-09 13:11
    Rayman wrote: »
    What does
    ORGH 0
    do exactly?
    In fastspin at least "orgh 0" will only work if it's the very first thing in the program. Otherwise you'd be asking the assembler to go backwards, which would be impossible.
    ORGH X
    In fastspin (and I'm pretty sure the other assemblers) "ORGH X" will try to insert padding to make sure the code/data will start at location X in hub memory. If there is already more than X bytes of things in HUB then it will report an error. There's no special case for $400.
    Note that unlike ORG, just plain ORGH on its own is *not* the same as "ORGH 0". Just "ORGH" with no number says "labels defined after this point are in HUB memory", but it doesn't change the hub memory location. So in:
       ORGH 0  ' first thing
       ORG 0 ' COG labels
    x  nop
    y  nop
       ORGH ' HUB labels
    z  nop
    "x" has the value 0, "y" as the value 1 (it's a COG address), but "z" has the value 8 (it's a HUB address). If the ORGH wasn't there, "z" would have the value 2.
    edited 2019-04-09 13:05
    Hmm... In that case, I'm surprised I didn't have an issue with "ORGH" yet...
    I thought there were some things that don't work if address is below $400.
    What was it? I think it was something about a relative vs. hub address...
    Or, maybe it is hubexec code doesn't work if below $400 ?...
  • evanhevanh Posts: 17,037
    Eric,
    Thank you! I never checked for that. I've tested it and it works just by adding a MOV x,#0.
    '*  VGA 640 x 480 x 8bpp-lut  *
    CON
      intensity	= 80	'0..128
      fclk		= 80_000_000.0
      fpix		= 25_000_000.0
      fset		= (fpix / fclk * 2.0) * float($4000_0000)
      vsync		=	0	'vsync pin (all FPGA boards now)
    DAT
    org
    ' Setup
    		hubset	#$FF			'set clock to 80MHz
    		coginit #2,##@PropCam_Acq
    		mov	x,#0
    		rep	@.end,#$100
    		rflong	y
    		shl	y,#8
    		wrlut	y,x
    		add	x,#1
    .end
    		rdfast	##640*480/64,##$1000	'set rdfast to wrap on bitmap
    		setxfrq ##round(fset)		'set transfer frequency to 25MHz
    		'the next 4 lines may be commented out to bypass level scaling
    		setcy	##intensity << 24	'r	set colorspace for rgb
    		setci	##intensity << 16	'g
    		setcq	##intensity << 08	'b
    		setcmod	#%01_0_000_0		'enable colorspace conversion
    		wrpin	dacmode,#0		'enable dac modes in pins 0..3
    		wrpin	dacmode,#1
    		wrpin	dacmode,#2
    		wrpin	dacmode,#3
    ' Field loop
    field		mov	x,#33			'top blanks
    		call	#blank
    		mov     x,#480			'set visible lines
    line		call	#hsync			'do horizontal sync
    		xcont	m_rf,#0			'visible line
    		djnz    x,#line           	'another line?
    		mov	x,#10			'bottom blanks
    		call	#blank
    		drvnot	#vsync			'sync on
    		mov	x,#2			'sync blanks
    		call	#blank
    		drvnot	#vsync			'sync off
                    jmp     #field                  'loop
    ' Subroutines
    blank		call	#hsync			'blank lines
    		xcont	m_vi,#0
    	_ret_	djnz	x,#blank
    hsync		xcont	m_bs,#0			'horizontal sync
    		xcont	m_sn,#1
    	_ret_	xcont	m_bv,#0
    ' Initialized data
    dacmode		long	%0000_0000_000_1010000000000_01_00000_0
    m_bs		long	$CF000000+16		'before sync
    m_sn		long	$CF000000+96		'sync
    m_bv		long	$CF000000+48		'before visible
    m_vi		long	$CF000000+640		'visible
    m_rf		long	$7F000000+640		'visible rlong 8bpp lut
    x		res	1
    y		res	1
    'endfold
    'comment
    'fold propcam
    org
    PropCam_Acq
    '		nop                      'if this is first instruction everything fine
    '		waitx ##80_000_000   'if this is first instruction ... no display
    		cogid camera_number  'if this is first instruction ... bad lut
    		cogstop #2            'if this is first instruction ... bad lut
    'temporary jmp
    temploop
    		nop
    		jmp #temploop
    camera_number	res  1
    'endfold
    ' Bitmap
    		orgh	$1000 - $436	'justify pixels at $1000, pallete at $1000-$400
    		file	"bitmap2.bmp"	'640 x 480, 8pbb-lut
    So, whole issue caused by a single uninitialised variable.
  • Rayman wrote: »
    You have to use RES carefully, but it does have uses. The main one is that it allows you to declare variables that you know will be initialized from elsewhere (e.g. data read from pins or SD card) without requiring that space be allocated in the binary. That can save a lot on load time, and also lets you fit more things into HUB RAM. For example:
    x res 100
    reserves space for 400 longs at runtime, but since it's not initialized you don't have to download that to the P2, and if it's in an ORG section it consumes no extra HUB RAM; whereas
    x long 100[0]
    makes your .binary file 400 bytes larger. In some cases this could be the difference between having code that fits in memory and not.
    edited 2019-04-09 13:15
    I would argue that you could just use FIT to achieve the same purpose with less risk...
    But, I do use RES, I'm just very careful with it after having been burned more than once.
    edited 2019-04-09 14:05
    Here's a modified version for driving the P2ES-Eval accessory board. If the MOV x,#0 at line 69 is commented out then things go bad.
    CON
    	XTALFREQ	= 20_000_000				'PLL stage 0: crystal frequency
    	XDIV		= 2					'PLL stage 1: crystal divider
    	XMUL		= 8					'PLL stage 2: crystal / div * mul
    	XDIVP		= 1					'PLL stage 3: crystal / div * mul / divp (1,2,4..30)
    	XOSC		= %10                             'OSC    ' %00=OFF, %01=OSC, %10=15pF, %11=30pF
    	XSEL		= %11                             'XI+PLL ' %00=rcfast(20+MHz), %01=rcslow(~20KHz), %10=XI(5ms), %11=XI+PLL(10ms)
    	XPPPP		= ((XDIVP>>1) + 15) & $F                  ' 1->15, 2->0, 4->1, 6->2...30->14
    	CLOCKFREQ	= round(float(XTALFREQ) / float(XDIV) * float(XMUL) / float(XDIVP))
    	SETFREQ		= 1<<24 + (XDIV-1)<<18 + (XMUL-1)<<8 + XPPPP<<4 + XOSC<<2
    	ENAFREQ		= SETFREQ + XSEL                          ' %0000_000e_dddddd_mmmmmmmmmm_pppp_cc_ss  ' enable oscillator
    'Serial functions for data logging
    	rx_pin		= 63
    	tx_pin		= 62
    	BAUDRATE	= 115_200
    	ASYNCFG		= round(float(CLOCKFREQ) * 64.0 / float(BAUDRATE))<<10 + 7	'bitrate format is 16.6<<10, 8N1 framing
      fclk		= 80_000_000.0
      fpix		= 25_000_000.0
    'vsync		=	0	'vsync pin (all FPGA boards now)
    vsync		=	4	'vsync pin (for Prop2-Eval accessory board)
    DAT
    org
    ' Setup
    '		hubset	#$FF			'set clock to 80MHz
    'Silicon frequencies
    		hubset	clk_mode			'switch to RCFAST using known prior mode
    		mov	clk_mode, ##SETFREQ		'replace old with new
    		jmp	#bootinit
    '***  Boot-loader can fill all four of the following  ***
    spare1		long	0			'hubRAM addr $010 - compatible reserved for system variable
    clk_freq	long	CLOCKFREQ		'hubRAM addr $014 - sysclock frequency, integer frequency in hertz
    clk_mode	long	0			'hubRAM addr $018 - clock mode config word, used directly in HUBSET
    asyn_baud	long	BAUDRATE		'hubRAM addr $01c - comport baud rate, integer baud in hertz
    bootinit
    		hubset	clk_mode			'setup for new mode, still RCFAST
    		waitx	##20_000_000/100		'~10ms for crystal/PLL to come up to speed
    		hubset	##ENAFREQ			'engage
    		mov	x,#0
    		rep	@.end,#$100
    		rflong	y
    		shl	y,#8
    		wrlut	y,x
    		add	x,#1
    .end
    		wrpin	dacmode_s,#0		'enable dac modes in pins 0..3
    		wrpin	dacmode_c,#1
    		wrpin	dacmode_c,#2
    		wrpin	dacmode_c,#3
    		setnib  dira,#$f,#0		'RJA:  New for real P2
    ' Field loop
    		call	#blank
    		call	#blank
    		call	#blank
                    jmp     #field                  'loop
    ' Subroutines
    		xcont	m_vi,#0
    	_ret_	djnz	x,#blank
    		xcont	m_sn,#1
    	_ret_	xcont	m_bv,#0
    ' Initialized data
    'dacmode	long	%0000_0000_000_1010000000000_01_00000_0
    'RJA:  New dacmodes for real P2
    dacmode_s       long    %0000_0000_000_1011000000000_01_00000_0         'hsync is 123-ohm, 3.3V
    dacmode_c       long    %0000_0000_000_1011100000000_01_00000_0         'R/G/B are 75-ohm, 2.0V
    x		res	1
    y		res	1
    'endfold
    'comment
    'fold propcam
    org
    PropCam_Acq
    'temporary jmp
    temploop
    		nop
    		jmp #temploop
    camera_number	res  1
    'endfold
    ' Bitmap
    Rayman,
    I've had bad experience too but, at this stage, it doesn't look to be the fault of the tools.
    edited 2019-04-09 14:11
    I also ran into the issue with x not being initialized. I posted a thread about this called Minor issue with VGA_640_x_480_8bpp.spin2 and VGA_640_x_480_16bpp.spin2. It worked OK in the original programs because the ORGH caused the memory to be padded out with zeros. However, if you put code immediately after x and y the memory will be nonzero.
    The RES instruction should be used with care. If a variable is required to be initialize to zero it is better to use "long 0" instead of using res, and then depend on the assembler to pad with zeros.
    For assembler mode, like PNut.exe works in right now, nothing will change.
    For Spin2 mode, though, there isn't going to be controllable absolute addresses because of how objects build. So, in the case if Spin2 mode, ORGH will only affect the assembler-aware origin, and will default to $400, and not allow addresses below $400.
    About RES, this is a very useful directive, but it is only good for allocating uninitialized registers within ORG'd code.
  • jmgjmg Posts: 15,199
    Rayman wrote: »
    I think there is room for both, but they need to be very clear about what they actually do, and where they are doing it !!
    As P2 is totally RAM based, there are code-gains to be had, by declaring a VAR and initialising it at the same time.
    Flash based MCUs have to load any initialized RAM vars, which costs time and code space.
    Some MCUs sweep RAM to clear to 0x00, as part of their init code. That approach does reduce code size and helps avoid 'oops' bugs.
    Arrays that are declared maybe should have an option to load a known value ?
    As mentioned above, large arrays could have a download cost, if their value is really don't care.
    Why can’t res vars be relocated to after declared registers?
    Rayman wrote: »
    The assembler would have to group them up under each ORG and arrange them before the end of the DAT block or before the next ORG or ORGH. It's a lot simpler to just place them manually and understand what they do.
    edited 2019-04-10 00:37
    Seems like there should be a warning in such cases...
    I like warnings
    Ignore them all the time
  • The RES directive is not a new directive for P2.
    It's has been used extensively in P1 code.
    The P1 manual explains it's use and even includes this statement.
    Caution: Use RES Only After Instructions and Data
    Caution exactly
  • cgracey wrote: »
    I would urge you to think about this again. Addresses were one of the problem points in Spin 1; I think people often tripped over the difference between @ in Spin and PASM. I know that making @ working as expected in mixed PASM and Spin is difficult. But it is possible -- homespun and bstc did it, for example (although they had to invent a new syntax, @ @ @, to maintain Spin compatibility).
    Now I'm confused... When do we need the triple-@?
    I found this quote from ersmith:
    Correct, code in a method can use (at)image to get the absolute hub address of a DAT symbol "image". (Code in a DAT section would have to use a more complicated method involving a run-time fixup, unless you're using bstc or fastspin, in which case triple (at) will do the trick.)
    Seems the triple is only for PASM sections?
    But, I think the tools right now already give us the absolute address of things when inside a PASM section.
    edited 2019-04-10 17:05
    Rayman wrote: »
    Not in Spin 1. On the Propeller 1, @ inside a DAT section always meant an address relative to the start of the DAT section. Right now in P2 code this is different and @ means absolute address, but I think Chip was talking about making Spin 2 act like Spin 1. I think this could end up being very confusing.
    In Spin2, hub-exec PASM code can be ORGH'd at any address >= $400, but it will never wind up there after compilation. With relative addressing modes within PASM blocks, though, all you'd need to know is the entry address, which is absolute and easy to determine at runtime, but not as ORGH'd. As objects are stacked together, there's no telling where some block of PASM code is going to wind up.
    Am I missing something?
    We'd have to have some kind of linker step to afford absolute addressing between uncommonly ORGH'd blocks of PASM code, right? It seems way more trouble than it's worth if we can determine an entry-point at run time and just use that, instead.
    So, my thinking is that ORGH'd labels return the absolute hub address via @label.
    Ok, that's mostly what I do now, except for the VGA bitmap, etc.
    There we currently rely on the orgh value, I think, so that would have to change somehow...
    edited 2019-04-10 19:08
    Couldn't there be two types of DAT sections with one type connected to a Spin object, and the other independent of an object? The independent one would look like what we have now with absolute addresses. The other type would look like the Spin1 DAT sections, where the addresses are relative to the start of the object.
    EDIT: Maybe the independent DAT section could contain global symbols that any object could directly address. That's a feature that would have been useful in Spin1.
