define a range in con section
in Propeller 1
Is there a simple, straight forward way to define a range of values in the con section? I've read through the CON section of the prop manual and don't see any close examples. I want to use pre-defined zones to test against in a case expression.
CON
_clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz
_xinfreq = 5_000_000
zone1 >0 AND <60 'define the range of zone1
zone2 ...ect
pub whatever |arc
dira[5]~~
arc:=25
repeat
case arc 'compare arc value to various zone ranges
zone1 : outa[5]~~
zone2 : outa[5]~
ect...
CON ZONE1L = 0 ZONE1H = 60 ... case arc ZONE1L .. ZONE1H: outa[5]~~ ...-Phil
