MCP3002 not displaying voltage jumps
in Propeller 1
Can anyone help me. I am using the sample program for the MCP3002 to display voltage. It only shows either "0" or 79.99 on both channels.
The following is the code I am using.
#include "simpletools.h" // Include simpletools
#include "adcDCpropab.h" // Include adcDCpropab
int main() // Main function
adc_init(8, 9, 10, 11); // CS=Pin1, SCL=Pin7, DO=Pin6, DI=Pin5
float v0, v1; // Voltage variables
while(1) // Loop repeats indefinitely
v0 = adc_volts(0); // Check A/D 0
v1 = adc_volts(1); // Check A/D 1
putChar(HOME); // Cursor -> top-left "home"
print("A/D0 = %f V%c\n", v0, CLREOL); // Display volts
print("A/D1 = %f V%c\n", v1, CLREOL); // Display volts
pause(100); // Wait 1/10 s
Anyone's assistance will be appreciated.
Dave
Dave
http://forums.parallax.com/discussion/comment/1221392/#Comment_1221392
Here is the code to read MCP3202 chip:
// millivolts times 1000 int mcp3202_read(int R) { unsigned int i; if (R == 0) i = 0xd; //1101 else i = 0xf; //1111 low(mcpCS); shift_out(mcpDIN, mcpCLK, MSBFIRST, 4, i); i = shift_in(mcpDOUT, mcpCLK, MSBPOST, 12); high(mcpCS); return i; } int mcp3202_volts(int R) { int i; i = mcp3202_read(R); i = i * 1000; i = i / 1226; return i; }Since this chip has two ADC lines the variable R is really the channel you want to read.
Also the MCP3002 is only a 10 bit resolution chip so you need to change the 12 above to 10.
#include <propeller.h>
const int ON = 254;
const int CLR = 1;
int main()
{ // Main function
int mcpCS = input(8);
int mcpDIN = input(11);
int mcpCLK = input(7);
int mcpDOUT = output(6);
unsigned int i;
if (R == 0)
i = 0xd; //1101
else
i = 0xf; //1111
low(mcpCS);
i = shift_in(mcpDOUT, mcpCLK, MSBPOST, 10);
high(mcpCS);
return i;
int i;
i = i * 1000;
i = i / 1226;
pause(100);
serial *lcd = serial_open(12, 12, 0, 9600); //Pin12 out,pin12 in,data bits 0,baud rate 9600
writeChar(lcd, ON);
writeChar(lcd, CLR);
dprint(lcd,"Volts %d", i); //display volts
pause(100);
return i;
Your assistance will be appreciated.
Dave
Also when posting, please use coding brackets, (the big C in the editor). This will show code as it is supposed to be viewed. When the "Code/code) shows up copy and paste your code between the brackets.
I used two resistors 10K each with 5 volts. This would result in a voltage of 2.5 volts
Attached is a picture of the setup with an MCP3204 chip connect between the two 10k resistors with a voltage reading of 2.5
#include "simpletools.h" // pre define function int readMCP3204(char); int readMCP3002(char); const char ON = 22; const char CLR = 12; const char H = 128; const char L2 = 192; #define BLTON 17 #define CLK 2 #define DOUT 3 #define DIN 4 #define CS 5 // high bit is start bit #define CHANNEL 0x18 #define TWOCHANNEL 0x06 int i; serial *lcd; float v; int main() { lcd = serial_open(8, 8, 0, 19200); //Pin12 out,pin12 in,data bits 0,baud rate 9600 writeChar(lcd, ON); writeChar(lcd, BLTON); input(DOUT); low(CS); high(CS); while (1) { i = readMCP3204(1); print("Value: %d\n", i); v = i; v = v / 4096 * 5; // digital output code =(4096 * Vin) / Vdd dprint(lcd, "%cVolts: %f", CLR, v); pause(1000); } } // c = channel pin // rotate 1 to set conversion start int readMCP3204(char c) { short v; low(CS); v = (CHANNEL + c) << 1; shift_out(DIN, CLK, MSBFIRST, 6, v); v = shift_in(DOUT, CLK, MSBPOST, 12); high(CS); return v; } int readMCP3002(char c) { short v; low(CS); v = (TWOCHANNEL + c) << 1; v = v | 0x01; // MSBF bit value shift_out(DIN, CLK, MSBFIRST, 4, v); v = shift_in(DOUT, CLK, MSBPOST, 10); high(CS); return v; }This code will not work for MCP3002 as it only has 2 inputs and require a MSBF bit. The readMCP3002 function should work instead. Also the reading changes as it is only 10 bits so the new formula is: reading = (1024 X Vin) / Vdd
Solving for Vin would be:
v = v / 1024 * 5
const char ON = 254;
const char CLR = 1;
const char H = 128;
#define BLTON 17
#define CLK 9
#define DOUT 10
#define DIN 11
#define CS 8
int n;
int i;
serial *lcd;
float v;
int main()
input(DOUT);
while (1)
i = readMCP3204(1);
writeChar(lcd, ON);
i = readMCP3204(1);
n = i;
n = n/10;
dprint(lcd, "Volts: %d",n );
pause(1000);
//c = channel pin
//rotate 1 to set conversion start
short v;
low(CS);
high(CS);
return v;
short v;
low(CS);
high(CS);
return v;
Dave
MCP3204 can return a value between 0 and 4096 (2^12)
MCP3002 can return a value between 0 and 1024 (2^10)
So the shift function it trying to return 12 bits instead of 10 for your unit. Also MCP3204 has a different select sequence so the bits returned will be shifted.
Using the MCP3002 function it should work correctly.
int main() { lcd = serial_open(12, 12, 0, 9600); //Pin12 out,pin12 in,data bits 0,baud rate 9600 writeChar(lcd, ON); writeChar(lcd, BLTON); input(DOUT); low(CS); high(CS); while (1) { i = readMCP3002(0); print("Value: %d\n", i); writeChar(lcd, ON); writeChar(lcd, CLR); i = readMCP3002(0); n = i; n = n / 10; dprint(lcd, "Volts: %d", n); pause(1000); } }Also you defined n as an integer so there is no decimal digits. So 1/10 = 0 where as if you use float it would return 0.1 as a value.
