using PLX DAQ to write to different Excel cells from an Arduino — Parallax Forums
I'm trying to write to varying cells in Excel from an Arduino Uno but can't find how to do it - or if it's possible.
Serial.print((String)"CELL,SET,",A6,50);
writes the value 50 into cell A6 with no problem but as soon as I try to use a string in place of A6 it bombs out.
Might be that I'm not getting the syntax correct or might be that it's not possible.
Can anyone help?
  • this sounds like a really good question for the Ard**no forum.
  • I don't believe PLX-DAQ is supported by Parallax any longer. There is a thread on the Arduino forums maintained by someone who has re-written the original PLX-DAQ program for non profit and to adapt to newer versions of MS Office Excel. You will find plenty of support at the following link https://forum.arduino.cc/index.php?topic=437398.0. It is also worth mentioning that the newer version still works with the Parallax range of micro controllers.
  • That's great - I'll try the Arduino forum.
    Many thanks for your help.
