Split personality IO pin
ozpropdev
in Propeller 2
I've been using the smartpin repository mode in my Micropython experiments and I discovered I can use the same pin as an output too.
In this example a pin is toggled at a spped set by it's own repository value.
This feature frees up pins for more fun!
con vsync = 56 dat org coginit #16,#@speed wrpin #%01_00001_0,#vsync 'long repository mode and OUT enabled dirh #vsync 'enable smartpin loop rdpin pb,#vsync 'get speed from smartpin repository getct pa testb pa,pb wc outc #vsync jmp #loop org speed waitx ##25_000_000 * 2 wxpin #23,#vsync 'slow speed waitx ##25_000_000 * 2 wxpin #20,#vsync 'faster speed jmp #speed
