HyperRam/Flash as VGA screen buffer (Now XGA, 720p &1080p) &Rev.B - Page 5 — Parallax Forums
1235789
  • evanhevanh Posts: 16,368
    Awe, yeah, dangly wires. Probably some decent ground bounce on that one.
  • cgraceycgracey Posts: 14,277
    This is looking great.
    Is clocking enabled on the pins, to align in and out timing with the clock?
  • Hi whicker
    Could you post a closer top-view of the Spansion HyperRam you are using at that setup and also if you have a link to the original datasheet of that exact chip?
    Also, is it possible for you to confirm you have the HyperRam chip soldered to a Proto Advantage's IPC0171 BGA-25 to DIP-25 SMT Adapter?
    Henrique
  • RaymanRayman Posts: 15,070
    edited 2019-03-25 12:53
    Thanks. I have no idea how to enable clocking... I'm just using plain WAITSE1 and then a WFBYTE INB,.. loop for reading.
    Wait, maybe I do know. I suppose one could enable smartpins on the bus and do something like that...
    Maybe a pulldown would be a good idea too...
    But this works perfectly as is.
    whicker wrote: »
    This is my first attempt at running the HyperVGA_640_x_480_16bpp_1d.spin2 code.
    Is there no capacitor on that HR board? Looks like it's almost working...
    I'd try the VGA 8bpp code and then turn down the P2 clock as low as you can...
    Rayman wrote: »
    It's a bit, %C, in the pin config bits when setting with WRPIN instruction. Right next to the invert config bits. I doubt you'll notice any improvement though. On the other hand it will give you an additional 2-clocks of lag from HRclock start to the data coming back. May be useful if needing more setup time.
    edited 2019-03-25 18:50
    One graphics updating strategy might be to buffer changes to the screen on a per line basis.
    Then, update that line after it is read in from HyperRam.
    Then, write it back into HyperRam.
    For VGA@8bpp, there's easily 16 us of space to edit the line. That's ~2000 instructions worth of time.
    Here's that scope capture again showing HyperRam access (when yellow trace is low) and VGA HSync (when green trace is high)
    This assumes though that we can write as fast as we read, which I think is true, but not demonstrated...
    3024 x 4032 - 2M
  • jmgjmg Posts: 15,190
    edited 2019-03-25 18:57
    Rayman wrote: »
    Have you tried a temperature sweep test ?
    Pin-register clocking enable tightens up timing skews, and especially variations with temperature.
    The present code syncs to RWDS, and then reads every second sysclk, so there is scope to have 2 sample phase choices.
    What is the output and input timing sample instant, relative to an opcode ?
    It may be better to wait on RWDS edge and then shift half an opcode (1 sysclk) so you sample away from the edge-zone. (in current 2 sysclk design)
    (Assuming WAITSE1 & WFBYTE INB have the same sample instant - the WAITSE1 may have an edge-sense-delay ?)
    Would that be a WAIT #3 as the shortest ?
    The faster 100MHz HRclk and 200MHz sysclk idea, samples every sysclk, so there is no SW adjust possible, but I think capture of RWDS pattern could give some modest timing check.
    If marginal, this may need some external hardware phase adjust.
    I think there is no 1 clock instruction.
    If there is an issue, which there doesn't seem to be now, maybe changing the RWDS pin to be smartpin and using Schmidt trigger mode would fix it...
    Or, if the RWDS timing really is fixed in this configuration, then we could do a 3-clock instruction in there to line it up better...
    Rayman wrote: »
    Yes, I think 3 is the smallest, odd delay.
    Rayman wrote: »
    I would tend to make the RWDS setting identical to the data-bus setting, to try and match-up their sampling instants, and select whatever pin mode gives the lowest skews, CLK-out and DATA-back.
    edited 2019-03-25 19:32
    jmg wrote: »
    I ran some quick Spice numbers on a simple RLC delay line, to get some ballparks for hardware delay lines...
    Delays 50% to 50% Tr,Tf = 1ns  Period = 10ns
    180/0.5pF/1nH/3pF    => 499.45474ps
    180/0.5pF/100nH/3pF  => 763.4584ps
    180/0.5pF/200nH/3pF  => 928.80259ps
    Digikey lists a series
    HK1005R10J-T Taiyo Yuden $0.01208/3k Multilayer Ferrite 100nH ±5% 200mA Unshielded 1.5 Ohm Max Q=8 @ 100MHz SR>600MHz -55°C ~ 125°C 100MHz Surface Mount 0402
    Seems things can be moved - I wonder how much P2 varies the sample window instant, with PVT ?
  • Rayman wrote: »
    I did add two 0.01 uF ceramic capacitors last night right after taking the photo. This was on the surface-mount part of the bottom of the board where +3V and 0V supply wires happened to be adjacent.
    Didn't change much at all, but having them there is obviously better.
    I'm thinking I'm missing pullups and pulldowns?
    RWDS might be picking up noise especially. Of any pin this is the most annoying because it tri-states and is input and output.
    Rayman, on your board, is CSn pulled up, and is RWDS pulled down? Or something different?
    I'm probably also going to directly solder the CLK wire and run a ground next to it if the resistors don't help.
    No pullups at all. I think you can make the pin a smartpin and give it a pulldown, might help.
    I think I now have RWDS as input only for reads.
    Most of the pin config bits in a WRPIN instruction are not a smartpin mode setting. So setting pullup/down features can be done to the plain OUT control. Just keep the %MMMMM bits as all zeros, for no smartpin, and you'll get IN/OUT bit-bashing with optional features like a pullup.
    Each DAC can be configured and operated without activating its smartpin. In fact using the streamers to control the DACs requires avoiding the smartpin.
    edited 2019-03-25 23:40
    The As, Bs, Fs and Ts are well documented in the main google doc. For the Ps I've done my best to transcribe Chip's Pin_Modes sheet - https://forums.parallax.com/discussion/comment/1452036/#Comment_1452036
    Thanks, there's still a lot I need to digest about the P2 I/O pins.
    BTW: I'm thinking about using two HR chips to make 16-bit bus...
    edited 2019-03-25 23:54
    Rayman wrote: »
    :) That's game, but cool. Are you making an accessory board each time? Actually, I'm not sure how you've got the existing HyperRAM mounted. I thought you had an adaptor between two eval boards but that might have been someone else.
    edited 2019-03-26 00:05
    Description of board is here: https://forums.parallax.com/discussion/169490/breakouts-for-p2-eval/p2
    I did add some WS leds to the other side, but hyperram part is the same...
    I was able to bring all the signals out without any vias under the chip...
  • rjo__rjo__ Posts: 2,114
    Fabulous proof of concept... excellent work. Thanks.
    In your first post you stated 125MB/s... is that number holding up?
    Rayman wrote: »
    Thanks. Good, a designed accessory board. You've got a good ground plane, check.
    DQ1 track needs some shortening to make it a better match to the others. RWDS track also should length match the data tracks. Maybe move the footprint up a little to make it closer to second header will help with the track lengths.
    You'll need a third accessory header to operate a second HyperRAM as 16-bit data. Obviously that's a different arrangement but do keep this guideline in mind when doing the layout.
    rjo__ wrote: »
    Yep, the source code confirms that at 250 MHz sysclock, it bursts at 125 MB/s.
                  rep   #1,##512
                  wfbyte    inb
    That one instruction copies a byte from INB to hubRAM in two sysclocks. Repeated 512 times give us the peak of 125 MB/s.
    Here's the source for burst reading after having issued the command to the HyperRAM chip:
                  setbyte   dirb,#$00,#0 'release control of buffer
                  'configure smartpin to run HR clock
                  dirl      #Pin_CK
                  wrpin     #%1_00110_0,#Pin_CK
                  wxpin     #1,#Pin_CK  'add on every clock
                  mov       pa,#1
                  shl       pa,#30 '250/4 = 62.5 MHz
                  wypin     pa,#Pin_CK
                  dirh      #Pin_CK
                  'prepare to load buffer using fifo
                  loc       ptra,#@HyperBuffer
                  mov       pa,HyperRow 'need 4 rows to fill buffer
                  and       pa,#3
                  mul       pa,##512
                  add       ptra,pa
                  wrfast    #0,ptra
                  'Wait for Pin_RWDS to go high
                  setse1    #$80+Pin_RWDS
                  waitse1
                  'read in bytes
                  rep   #1,##512
                  wfbyte    inb
    Note it doesn't seem to need to be quick about the setup.
    That's one really nice feature of HR, the clock can be lazy...
    I was reading another manufacturers datasheet and remember thinking that the text is nearly verbatim...
    I wonder if there's a common spec that they all have to meet...
    Today, I'm going to dream about what I could do with 4 HR chips to make a 32-bit bus...
  • Hi Rayman
    I hope you already has them, but, just in case...
    The last available version (Document Number: 001-99253 Rev. *H) of HyperBus™ Specification, Low Signal Count, High Performance DDRBus, can be freely downloaded at Cypress site, at the link:
    https://cypress.com/file/213356/download
    Apart from any device caracteristic/specific data (available at its most recently updated datasheet) , all non NDA-dependant information you may need can be found there.
    Since you are laying out your own boards, there is another interesting reading:
    Cypress: AN211622 HyperFlash™and HyperRAM™Layout Guide, Document No. 002-11622 Rev.*B , available at:
    https://cypress.com/file/278156/download
    Hope it helps
    Henrique
    edited 2019-03-26 16:55
    It might have helped me to have seen the recommended layout...
    I think I probably violated most of their recommendations.
    But, I'm less than half of the 333 MBps max. possible read rate.
    I thought I was pretty smart when I was able to bring all the traces out without vias, but now I see that it was designed that way!
    925 x 721 - 159K
    Just had a thought about better alignment of HR data with INA clock...
    I could sacrifice the first byte or two in each row and insert a 3-clock RDLUT instruction before reading in row data.
    In the current configurations, I'm not using all the data in each 1024 byte row...
    But, seeing as I'm not having an issue, I'll probably just leave as is.
    Rayman wrote: »
    It could be worth seeing if it is any worse, or just as stable ? - add some warming and cooling in there too.. ?
    It's not easy to nail down the exact slot timing, from the docs, and it may be a Rise detect uses D-FF's+Gate, which has a built in 1-sysclk delay ?
    ie If that's the case, adding a single sysclk offset, may make things worse....
    Put another way, does wait for high, have identical edge relative timing to wait for rise ?
    Rayman wrote: »
    I think that's related to the need for a second source, otherwise no one designs it in.
    edited 2019-03-26 20:45
    Hi Rayman
    As weird as it can appear to many people, the true access time limiting factor, at least for 3.0 V parts, is at the interface circuits, crafted to communicate with the external world; they are switching-voltage-related.
    There is a lot of externally generated noise being picked-up by the internal interface circuits, that also has to deal with its self-generated noise, and the one that is produced at its close vicinity, by underlying circuits: the next sensible element at the data chain, the main and aux full-row buffers, 1024 bytes-long, each.
    To the point they had to limit the specced transfer rate to 200 MB/s (HyperClk = 100 MHz max.).
    To achieve 333 MB/s (@ 166 MHz HyperClk), they had to lower the interface voltage levels (1.8 V) and agregate a second clock, CK#, in order to better sync the transfer of data, while relegating to the applications designer/engineer, the burden of ensureing the right phase and timing of both CKs, RWDS and Data lanes.
    So the real point is: irrespective to the version an application uses (3.0 V or 1.8 V), good signal conditioning and impedance matching always pays for itself.
    At the end of the day, statistics ever bites; without any ECC error-correcting provisions, a single bad readen/writen bit can mostly trash a whole application. Or, at least, be cause of some head aches and incurring not-so-gentle phone calls (back to the old days; now e-mails, for real world applications).
    Always remember, the original market HyperRam was intended for, was to enable XIP, as part of a cache scheme. That is the reason it has so many commands intended to rapidly fill a cache line. The early Spansion designers were targeting the $$$$ bucks of massive automotive applications markets. HyperFlash was designed with that kind of application in mind.
    The uses HyperRam finds at screen buffers, with its single linear burst transfer mode, are a foreseeable sequell.
    Better stay within the best tracks you could craft (pun intended).
    Henrique :lol:
