Help with Keyboard Input
in Propeller 1
I'm running the Propeller Tool on my laptop. It's connected to the Prop with a PropPlug.
I want to be able to read the laptop keyboard when typed in to the input bar at the top of the tool.
Which library routine should I use to do this. I should know, but it's been too long since I did it.
Thank you for your help!
Jim
Jim
What you are looking for specifically, is on page 106 and uses the "EnterAndDisplayValues.spin" code from the PE Kit folder.
Thank you for the feedback. I AM using the Parallax Serial Terminal.
Can you give me a simple example of how to read the input from this into a spin program?
Thank you!
Jim
Jim
