Propeller on a FPGA MAX10 as open source design
in Propeller 1
Hello,
will it be possible to implement on a MAX10 (10M08 or 10M16 or 10M25), a propeller 1 ? Even in removing ROM of the hub (generator character, sinus table, log table,...)
Because there is some small eval board low cost like MAX1000 from Arrow, SNO from Alorium, and so on.
Is there someone who has tried this, please ?
Thank you in advance for your reply.
M-O
M-O
So yes it can be done, but you'd want at least a 10M25 to fit a full P1V with 8 cogs.
Again from memory the clock rate was around 130 MHz for the standard commercial grade C8G, you can get it going a bit faster using faster grades if you need to.
With a 10M16, what can you get without ROM ?
